Old 07-23-2002, 03:41 PM   #1
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Arrow D44 Axle seals HELP!
I started to put my front axle back together when I realized that I was missing the seal between the housing and the axle itself (a PO didn't bother to put them in last time they tore it down!). According to the books at NAPA, the seal should be #13165 but it doesn't fit. I tried a national #5131 at CarQuest and it is the exact same seal NAPA has (even stamped with 13165) Does anyone know what Part Number I need to be looking for? I'm getting desparate - suns out and I want to drive the beast again!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-23-2002, 04:08 PM   #2
Pont
I need another Barley Pop
Pont's Avatar
Try a National #442380
This is the inner seal, right? Not the outer hub seal.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 07-23-2002, 04:18 PM   #3
Blazer1970
Blazer1970's Avatar
You understand that the seals are installed at the inboard ends of the axle tubes, right? They are installed from inside the housing, and you have to remove the carrier to get them in.
Blazer1970 is offline   Reply With Quote
Old 07-23-2002, 04:41 PM   #4
palallin
The '69 should be the closed knuckle design: is that still true?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 07-23-2002, 04:49 PM   #5
bouncytruck
SKINNY TIRES RULE!
Thanks guys, I didn't realize that the seals are installed on the inboard side of the axle tubes. I guess that's why it wasn't fitting and why there were none when I tore it down!
JUST BECAUSE I LOOK DUMB, DOESN'T MEAN I'M NOT!
bouncytruck 1972 K5
Old 07-23-2002, 09:12 PM   #6
Mike C
Mike C's Avatar
I assume your truck has a later open knuckle axle swapped in?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
