Got 20's????
What vehicle should I get one off of? I have an edelbrock performer intake and don't know if there is a certain one that would fit better or not.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
CCRider
http://www.tvmadeez.com/Installation.htm
------------------ 72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
L.E.D. Freak
I got mine down at AutoZone.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
Bowtie Overdrive sold me a TV cable kit and bracket. The bracket was the same one for the turbo 350 cable! The transmission guy told me to send that sh$# back and he pulled out a universal cable and used the old turbo 350 bracket. He then attached it to to the carb where the old trans cable connected. He drove it down the road. Stopped, made an adjustment, and then sent me home.
------------------ 71 C20 Cheyenne 71 K10 SWB Cheyenne 72 C10 Cheyenne
68 50th Longhorn Custom Camper 396 A/C 25 options 71 C20 Cheyenne 71 K10 SWB Cheyenne 72 C10 Cheyenne ----------------------- Slaughter, La |
its all about the +6 inches
Hmmmm, you might want to have it looked at by a more reputable tranny guy. That isn't the proper way to set it. Need pressure guages hooked up to the tranny.
The TV cable controls the amount of oil psi inside the tranny. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
Longhornmail is absolutely right. The "factory" TH350 bracket and mounting stud on the carburetor is not positioned appropriately for the TV cable to work properly. You will need to move the cable mounting stud to a position which gives you immediate pressure rise as soon as the throttle begins to open, and pulls to full extension at WOT (but not so it stretches the cable, or resets the cable housing adjustment). You'll know if it is adjusted properly with the aforementioned pressure rise as soon as you depress the throttle pedal, and if it will do a 2 gear downshift (yes, two gears!) to first while rolling along slowly in 3rd gear. It will take a little trial and error to get the mounting stud in the correct position.
'72 Cheyenne Super 4x4, 468ci, 700R4, Import Stomper. A couple pics at http://www.picturetrail.com/gallery/view?p=6&uid=529895& |
xwrench2003
The cable does control line pressure inside the unit and djustment MUST be correct to eliminate tranny damage. Depending on your carb type, TPI makes a small bracket that bolts to the throttle lever of Holley carbs, it positions the cable mounting stud in a way to provide the proper line pressure throughout the entire throttle range. I have used this configuration for 4 years with no problems. Good luck
------------------ Marty Hall Taylorsville, Ky 1971 C-10 SWB fleetside (355,700-R4) 1971 K-10 LWB Cheyenne (454\turbo-400) 1972 C-10 SWB stepside (6-cyl) 1949 3100 chevy panel delivery (original) 93 S-10 Blazer 93 S-10 Pickup
Marty Hall 1971 K-10 LWB Cheyenne (461\T-400) 93 S-10 Blazer (330,000 and still going) 86 SS Monte Carlo (40,000 miles) 85 Chevy Scottsdale 02 Jeep Liberty |
got mine at hi-po shop in town fits with my edelbrock ---- runs great cable and bracket about 25.00- 35.00 make sure you set it correctly---- the one I have has a ratcheting type do hickey for adjustment -- install everything then unclick lock full to just short of full throttle then lock down should work fine --
68 c-10 lwb to swb 383 lr stroker 700 r4 starting frame off now phoenix, arizona |
