Old 03-21-2005, 10:41 AM   #1
67_C-30
I have a radical idea!
67_C-30's Avatar
SM420 Transmission Shifter Question
I have a SM420 4 speed in my '67 C-30. The transmission works very good. It shifts very smooth, and is very quiet. It only has 61,000 miles. The only thing about it is that the shifter kinda rattles in 4th gear. Are there bushings that can be replaced to stop this, or is there something else you have to do. I've never torn into one, so I know nothing about them. TIA!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-21-2005, 09:03 PM   #2
67_C-30
67_C-30's Avatar
ttt
My trucks
Old 03-21-2005, 09:14 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Usually after about 30 years the tip of the shifter that goes into the top of the tranny can break loose and wobble around, which causes slop in the shifter. The shifter in the 465 I'm putting in my truck is the same way, but it wobbles in all gears due to the tip of the shifter being loose. Hope this helps.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 03-21-2005, 10:29 PM   #4
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
IIRC, the shifter is two pieces. One is the long rod the knob attaches to, the other is a small shaft (the tip Robert is talking about) that slips inside the long rod & is machined to slide around the shifter rails.
When I cleaned up my SM420, I pulled that small shaft out, put some new O-rings on it, slid it back in, and replaced the roll pin that holds it inside the long rod.
However, that's not going to get rid of ALL the slop. The machined flats in the shifter rails are quite a bit larger than the ball end of the small shaft. AFAIK, there's no bushing that slides over that ball end.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 03-22-2005, 12:19 AM   #5
67_C-30
67_C-30's Avatar
Did the O rings help it though? If the tip is broken, can they be bought new, or will I have to try to find a good used one? Thanks again!
My trucks
Old 03-23-2005, 05:14 PM   #6
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
My local GM parts guy (who I trust about as far as I can throw my truck) says the tip isn't available separately - you have to buy the entire shift lever. Oh, wait - never mind. That part has been discontinued.
I was asking for the SM465 lever, which I know was used through 1987. That doesn't bode well for the SM420.
I hope someone here knows better, that there is still a source for such a common part. Is someone aware of a GM dealership somewhere that is friendly to us pre-73 fanatics and will ship nationwide?
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 03-23-2005, 10:05 PM   #7
CE20934
CE20934's Avatar
The O-rings helped, yes. Not a whole lot, but a bit.
Your tip isn't broken. Trust me, if that little tip is broken, you're not going to be rowing any gears at all. Plus it's damn near impossible to break them, especially from normal use.
Old 03-24-2005, 11:13 PM   #8
67_C-30
67_C-30's Avatar
I guess when I do the engine swap, I'll try the O rings and inspect all the parts for anything unusual. Thanks for help!
My trucks
