Old 03-23-2005, 03:22 PM   #1
shifty
Questionable
shifty's Avatar
Talking Name this part? Also, speedo questions (not the underwear)
What is the name of the gear inside the tranny that your speedo cable hooks up to? I need a new one ...
My truck came with a 60" speedo cable sheath. It seems to be stretched awful tight. Would I have any problems using a longer sheath - like a 66" - with a 66" speedo cable?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-23-2005, 03:33 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Speedometer Gear
Your cable is tight because the transmission in your truck was swapped out for a 69-up version. The 67/68 3 speed tranny is shorter. You need to get a cable that will work on the longer tailshaft transmission, Since that tranny is the same length (bellhousing to slip yolk) as the stock TH350 auto tranny, get a used one off a automatic equiped truck, or buy new for that application
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-23-2005, 04:06 PM   #3
shifty
Questionable
shifty's Avatar
What kind of parts store sells a speedometer gear? The local Discount Zone stores keep redirecting me to transmission shops. Transmission shops redirect me to the auto parts store. Someone at a tranny shop tried to tell me I was looking for a "spider gear", which I thought was incorrect (hence why I started this thread).
Thanks, yet again CPNE
Old 03-23-2005, 04:40 PM   #4
busterwivell
I've had them made at the calibration shop. That way, everything is right. Avoids tickets with new toys (well, maybe).
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 03-23-2005, 05:33 PM   #5
teamroper!
teamroper!'s Avatar
speedometer driven gear. If your speedometer is correct, remove the gear and take it to a dealership and they should be able to help you out.
teamroper! is offline   Reply With Quote
Old 03-23-2005, 06:38 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
speedometer gears
I don't know if this will help but check the link
http://images.google.com/imgres?imgu...lr%3D%26sa%3DN
VetteVet
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-23-2005, 07:39 PM   #7
68jimmy
68jimmy's Avatar
I've only had luck at the GM dealer obtaining the gears... And they're not out of site, around $7-10$ each... The gear that is attached to the output shaft is the Drive gear and the other is the Driven, which is the one that the speedo cable slips into. To calculate what you need based on your rear axle ratio and tire size use the calculators at:
http://www.tciauto.com/tech_info/speedo_gears.htm
good luck!
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 03-23-2005, 09:04 PM   #8
shifty
Questionable
shifty's Avatar
Thanks, guys! Now I have the pleasure of finding out the gear ratio on the truck, I guess. I honestly have no clue. Just got it. I don't even know how many bolts
