Old 03-23-2005, 06:50 PM   #1
blownz
Active Member
700R Swap
I was thinking about swappinp a 700r4 for t400 in my 84 k10. It has a 208 tansfer case with the 700 r in front. Is there any tricks to this swap? It looks like a direct swap. Any info would be great.
I am new to the forums
Wayne
blownz is offline   Reply With Quote
Old 03-23-2005, 06:59 PM   #2
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
That's funny 'cause I may be doing the opposite soon.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 03-23-2005, 08:15 PM   #3
Sailor77
Yeah there are a few things you will and may need to do.
Get correct TV cable, dip stick
You may need a new yolk on the rear shaft and possibly a front driveshaft depending on splines. Last one I did needed both.
The crossmember is different too, all this can be had from a junk yard if needed.
You will need a way to lock up the TC. There are many products available that will do this or there are several write up that will show you how to make one yourself.
Since you are swapping in a transfere case too, make sure to get all the parts with that, shifter, rods ect.
If you have all the parts it doesn't take long or much thought about doing.
Good luck!!!
85 chevy 1/2 4x4, stepside.
New 350, 700R4, Auburn limited and 241 transfer.
Sailor77 is offline   Reply With Quote
Old 03-24-2005, 09:24 AM   #4
Brad_Olson
Active Member
Brad_Olson's Avatar
You'll need an electric kickdown switch as the TH400 doesn't use a cable. IIRC most factory switches were placed under the gas pedal.
Brad
Brad_Olson is offline   Reply With Quote
