Old 03-27-2005, 01:10 AM   #1
junkyard truck
junkyard truck's Avatar
stepside fender mounting
who can tell me if there some type of gasket between the rear stepside fenders and the the bedside. fenders seem to be noisey and maybe i forgot the gasket to cut the rattle noise,
69 chevy short stepside
junkyard truck is offline   Reply With Quote
Old 03-27-2005, 01:55 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
They originally just had some caulk like material between them,but if you are getting noise check all the bolts and braces.
sneakysnake is offline   Reply With Quote
Old 03-27-2005, 02:18 AM   #3
krue
Designated A-hole!
krue's Avatar
LMC has a vinyl gasket type rig that I tried. I hate it, looks like crap. Next time I remove the fenders when they go back on I am gonna get some of the stuff the electricians on my last submarine called "monkey sh!t", which doesn't set up and dry out. That's what the factory stuff looked like.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-27-2005, 10:38 AM   #4
Pilgrim
Monkey dung is also good for sealing anything that comes through the firewall.
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 03-27-2005, 11:52 AM   #5
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Your local body shop will sell a product called GM Strip-Calk that is intened to be used between the fender flange and body. It is a sticky black material that looks like black licorice roll candy that you put between the flange and and fender. When you tighten the bolts it extrudes to fill the joint and then scrape away the excess if it happens to extrude out of the joint. It is not very expensive and you will get enough to do several trucks in one box but it should last forever.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-27-2005, 12:44 PM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
There should be "fender welting" in between the fender and bedside. I got mine from Chevy duty and it works well, looks great. They had black or chrome.
I like the idea of sealing that area with seam sealer/body caulk but I'd be afraid of sealing in moisture or trapping water and making matters worse.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 03-27-2005, 01:41 PM   #7
krue
Designated A-hole!
krue's Avatar
That's the same stuff I have now. My fenders were taken off the truck when it was new and stored in a barn until I bought the truck. The fenders (which looked brand new) had a kind of caulk on them, it ws nothing like the fender welting and I won't be reusing the fender welting.
www.daveramsey.com
