03-28-2005, 08:05 PM | #1 |
Schrader Valves
I am having a problem finding some manual fill schrader valves. Everybody has all the other fittings but no schrader valves. I'm doing a static drop with manual fill to start. So I need 4 valves that I can mount in a bracket mounted to the back by the license plate.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
03-28-2005, 08:36 PM | #2 |
Locally, I'm not sure. I do know AirRide stocks them because I got mine through them for $5 ea.
03-28-2005, 08:41 PM | #3 |
Shortbox wanna-be.
If you are in a real bind, I may be able to dig you up 4 new ones. But shipping would probobly cost you $15.00 so maybe are better off getting them from air ride.
Reid
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) |
03-28-2005, 11:45 PM | #4 |
well man i work at oriellys and they can get them. if you have one locally go in there and tell them to pull there camel book and find a manual fill tank valve. camel is who makes all there valve stems and cores and so on. at least thats the way it is here in texas. just tell them to check and see if they have one in stock and if not they should be able to get one the next day as long as its before 4 45.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
03-30-2005, 07:10 PM | #5 |
Just Don't Stop!
I boght mine off the shelf at Oriellys just like Orange72 says....
1968 C10 build in process TT LSA/6L90e/9" |
03-31-2005, 10:12 AM | #6 |
Trucker.
A-Z hydraulics off MarkIV and 820 have them. They are on your left hand south of 820 on MarkIV Pkwy. They are only open until 5 and closed on weekends. I got some 1/8" schraders and some 1/8"x1/4" reducers for $1/each.
