Old 03-29-2005, 12:28 AM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
bb 402 help
getting ready for the bb swap.i have the correct 72 towers.is there room for a long water pump and 4 core rad
also what models would be best for the pulleys/brackets/ps pump for the long pump
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 03-29-2005, 12:37 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I don't remember if mine has a long or short pump but it does have a 4 core rad from the factory. When I did my BB swap I couldn't use the pullies that were on the motor so I used a set from an 86 350. The PS pump is from a 78 BB truck. Don't know if that helps but I thought I'd throw it out there for ya...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 03-29-2005, 02:59 AM   #3
Orence1
Orence1's Avatar
Shadetree,
Yes to all the questions you asked. I have a 402 in a 72 LWB with a long water pump and a 4 core radiator. I am using some stock pulleys and had no problems with clearance. The fan is a plastic flex-a-lite with an off the shelf spacer. I did the intallation myself. Original motor was a 350. I do have the correct 72 towers installed in the front holes. Good luck. Feel free to PM me with any furthur questions.
Larry
Orence1 is offline   Reply With Quote
Old 03-29-2005, 09:57 AM   #4
72 Cheyenne402
72 Cheyenne402's Avatar
Mine has a short water pump
72 Cheyenne402 is offline   Reply With Quote
Old 03-29-2005, 07:05 PM   #5
72shadetree
KEEP ON TRUCKING
thanks alot i know its suppose to be short but the long brackets and stuff are alot cheaper.
what year did thet start using long pump on bb
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 04-05-2005, 10:00 PM   #6
Swbman
on gm cars the shortwater pump was used on bbc til 1968,the 69 model year was the first year for longwater pump, on chevrolet trucks shortwater used til 1972 on your 396 402 and your badged 400 which was either a 396 or a 402.The longwater pump showed up for the first time in 1973 on the trucks.
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
