Old 03-29-2005, 07:05 PM   #1
dbzs
Needed right rear quarter 72 burb
Looking for a right rear quarter panel skin for a 72 suburban 3/4 ton.
dbzs is offline   Reply With Quote
Old 03-29-2005, 10:17 PM   #2
bagged91
Out draggin'
bagged91's Avatar
Welcome to the board! As far as the 1/4 skin goes, you and everyone else is too! They don't make a full skin for the burb/panel. They do offer the lower rear portion and a taillight section and the 3rd door outer rocker panel was just released but that is it for burb specific sheetmetal besides the door shells.
If you are just trying to fix some lower rust, then I would suggest the lower rear burb patches to fix the area behind the wheel and the front lower sections for the blazers to do the area in front of the wheel arch. The wheel arch itself is repop'd but I'm not happy with the quality of the stamping personally. The arch has a defined bead in it as the front fenders do and the replacement arches available look like the bead was flattened. They are actually pretty close to being correct for a LWB bedside patch but for a SWB/Blazer/Burb or Panel, they fall far from the mark.
My suggestion to you if you are in need of the entire arch and lower front section, then look for a decent SWB bedside to cut up for a patchpanel. While not the cheapest option, it will give you the correct wheel arch. Also, the lower front of the LWB arch has a more rounded corner than the others...
Hope this helps...
Joe
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 03-30-2005, 03:26 AM   #3
dbzs
I wish it was rust
Thanks for the info. Unfortunately rust is not the problem, accident damage is. The rear quarter took a hard hit behind the wheel arch and kinked enough body lines that a full skin is my best option.
