Old 03-30-2005, 02:34 PM   #1
Purs
Got Big Block?
Purs's Avatar
Brake hoses
I talked to a lady from McGaughy's yesterday about brake hoses for my '68 that I'm converting to disc's. The reason I called McGaughy's is that those are the spindles I'm using. She said that I could buy brake hoses for an '80 model camaro and they'd work perfect. Can anyone verify this? thanks!
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 03-30-2005, 06:22 PM   #2
raggedjim
raggedjim's Avatar
Not sure of the Camaro, but the '79 Chevette sounds promising...
http://67-72chevytrucks.com/vboard/s...light=chevette
raggedjim is offline   Reply With Quote
Old 03-30-2005, 06:25 PM   #3
Low69CST
I take it you have the original cross memember in your truck with the brake bracket to the rear. I had a problem with my lines kinking, so I went to a braided line with a 90 degree banjo fitting on the caliper. They work fine.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
