Old 03-31-2005, 03:40 PM   #1
RShaips
Vibration in drive line ?
I have a 67 SWB that is sitting on a 71 frame. This truck was a total restoration. I am having some vibration that I can feel as I drive it, the faster I go the worse it gets. It has a new driveshaft, that has been balanced and a 700R4 Tranny. It feels like its in my driveline somewhere, I ran it off the ground and everything looks ok. how can I tell if I have a bent axle? Wheels are spinning decent and wheel bearings feel tight. I just put this tranny in, could it be causing this? I don't think its the problem, just can't narrow it down to location, feel it in the seat, mirror vibrates, not in the front end at all. Its a tight fast vibration. Help !
RShaips is offline   Reply With Quote
Old 03-31-2005, 03:54 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re-Check the u-joints or drive shaft itself.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-31-2005, 04:01 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Was the tranny mount a bolt in or did you have to drill holes to mount it. Also, did you use stock motor mount holes? Could be possible your out of line somewhere, but I'd check the u-joints, then driveshaft, and go from there.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-31-2005, 04:04 PM   #4
Low69CST
did you put in a one piece driveshaft or 2 piece? Could be a midshaft bearing.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 03-31-2005, 04:22 PM   #5
RShaips
I put the tranny in, its a new one piece driveshaft, U joints are new and tight. I did have to drill holes to move the crossmember back and put a new rubber mount on.
Old 03-31-2005, 04:23 PM   #6
shifty
Questionable
shifty's Avatar
Driveshaft alignment? Is it possible the angle is out of whack? Do these trucks have problems when lowered or raised where the driveline needs pinion shims?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-31-2005, 04:42 PM   #7
RShaips
I don't know ,but my truck has a 2/4 drop with springs.
Old 03-31-2005, 04:51 PM   #8
67ChevyRedneck
That could be it. The driveline angle should not exceed 3 degrees. The angle could have caused the u-joints to go bad. jmo
Jesse James
Project "On a Dime"
Old 03-31-2005, 04:51 PM   #9
screamin_c102
screamin_c102's Avatar
First, is the vibration at speed? Or at engine speed? Take the truck up to 65 and put it in neutral, then see if you can feel the vibration, if you can then its more than likely in your driveline and or axle and hubs.
If you cant feel the vibration drop the truck back into drive, not OD but D and see if you can feel it now. If you can then it is probably something to do with the new tranny, as I believe you did not change the motor out I would rule it out right away. Did you change out your torque convertor? and if so are you sure it is completelt seated against the flexplate?
I had a B&M torque convertor that would not center into my crank just because of the paint buildup on the convertor, caused a wicked vibration at engine speed.
Just my $.02
screamin_c102 is offline   Reply With Quote
Old 03-31-2005, 05:00 PM   #10
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
if you lower or raise your truck, you need to check/correct the pinion angle.
good reading:
http://www.drivetrain.com/driveline_angle_problem.html
http://www.iedls.com/ptsetup.html
http://buickperformance.com/Pinion.htm
http://www.2quicknovas.com/happypinions.html
http://www.carcraft.com/howto/91758/
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
Old 03-31-2005, 05:11 PM   #11
RShaips
Wow, Lots of info there ! I guess that could be it, it feels like a high frequency vibration. I am pretty sure it does still vibrate when its in neutral, have to check again. It feels exzactly like my ujoints are loose. Don't ask me how I know how this feels ! LOL
Old 03-31-2005, 05:25 PM   #12
curbyk
69 C-10 project
curbyk's Avatar
Don't know if this would cause a vibration but did you have the drive shaft made before or after you lowered the truck and is there any or enough movement (in and out) of the yoak at the transmission?
69 C-10 Work is complete
curbyk is offline   Reply With Quote
Old 03-31-2005, 05:46 PM   #13
RShaips
I had the driveshaft made after I lowered the truck and there is plenty of room for movement where it slips over the splines on the tranny. I did not bring my truck in I just measured the distance and had one made.
Old 03-31-2005, 11:43 PM   #14
RShaips
If my axle was bent would I be able to see the wheel move out of round as it was running ?
Old 04-01-2005, 12:57 AM   #15
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
depends on how bad/where it's bent.shgould see unusual wear pattern on tire/tires.
best to pull it & check on a v-block set.
Old 04-01-2005, 10:51 AM   #16
chevybill
chevybill's Avatar
I have a question..
I have a 70 c 10 with 2.5 drop spindles with stock height springs in front and I have 3 inch lowering springs for the rear ( yet to be installed with my rebuilt rearent with my eaton posi unit).
I am using the factory spring mounts and factory trailing arm mounts.
Should I be concerned about a change in the pinion angle? I plan on using my factory 3 speed manual and factory driveshaft (after checking and rebalancing).
Am I ok since I have lowered the truck almost the same amount front and back? Truck is a lwb if that makes a difference.
Thanks guys.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 04-02-2005, 02:42 AM   #17
chevybill
chevybill's Avatar
ttt
Old 04-02-2005, 12:27 PM   #18
purple gas
First thing I'd do is check all your tires for ballance and alignment. It's easy & cheap to do. It'd be a B*tch to do a bunch of drive line work and then find out you just have a a wheel weight out of whack.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 04-02-2005, 12:37 PM   #19
Big Block
Big Block
Big Block's Avatar
I had 71 GMC short bed fleetside. Had the same problem. I did a engine & trans swap and still had vibration. Had the drive shaft balanced. Still had vibration. It ended up being a rear axle bearing. B.B.
Big Block is offline   Reply With Quote
Old 04-02-2005, 02:40 PM   #20
1-PU70
1-PU70's Avatar
Try rephasing the drive shaft. Unbolt it from the rear end and turn it 180 dg and then bolt it back up. Helps a lot of times.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 04-03-2005, 06:42 PM   #21
RShaips
Thanks for the replies, I have been out of town fishing the last few days so I have not had a chance to try anything. I get to it this week.
