04-02-2005, 10:38 AM | #1 |
crossmember??
What years use the same front crossmember? Could I take the crossmember out of a late model and put in to my 66? What years will work? I am planning on doing a cross member drop, and brake conversion, and drop spindles. Could I do this to eliminate the need for a brake conversion since I have to take it out any way?
04-02-2005, 04:27 PM | #2 |
To my understanding the '73-'87 cross member will work with your '66. Now if the i/2 ton is different than a 3/4-1ton I would not know. Hope this help's
MK |
04-06-2005, 12:54 PM | #3 |
Any one else i dont think i am going to do the crossmember drop now.
Will i have any issues if i take my crossmember out will say a 84 bult right up? |
04-06-2005, 02:51 PM | #4 |
It should fit fine except for two bolts. You will have to elongate the holes to get those two bolts to fit. Also IIRC you will probably have to do some bending to get the brake lines to hook up.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
04-06-2005, 03:38 PM | #5 |
thank you every onei need all the help i can get
05-14-2005, 05:06 PM | #6 |
A buddy of mine put the whole front-end out of a '77 under a '66 and he told me everything bolted fine accept two rear bolts that he elongated the holes on. So Neonlarry is telling you the straight scoop !!!
05-15-2005, 12:12 AM | #7 |
i just put a 91 sub in my 65 their are 4 bolts that dont line up 2 on each side I switch the idler arm with the 65 and that work.
05-25-2005, 02:29 PM | #8 |
What about something newer like a 95? Anybody try that? hogging out a few holes is no big deal.........
05-25-2005, 05:31 PM | #9 |
www.73-87chevytrucks.com
After 1987, the control arms are bolted to brackets that are welded on the top of the framerails and the crossmember is actually a welded structure on the frame.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
