Rear bags, No Notch (yet)
If I have four inch drop springs in the rear now, and I do manual fill Firestone 2600's with no notch how much more of a drop can I get at ridehight? Ill take care of the shocks and panhard bar. I’m only doing manual fill and no notch in the interest of money. (I’m trying to finance my truck and tattooing at the same time.)
63 fleetside swb -2/4 drop -Shaved Passenger door handle and all molding -hidden tailgate latches -Pseudo Frenched taillights -350/350 with shift kit -Dynomax ceramic coated headers -Edelbrock 600 carb -Edelbrock performer intake |
![]() Join Date: Jun 2002
I have a 6" static drop (4" springs and 2" blocks) That is about as low as you can go without c-notching.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
Here is a pic of my sons truck. 8" static drop. 6 inch springs and 2 inch blocks. With a bolt in c-notch from CPP (112.00 delivered)the top of the rear axle sits just about where the bottom of the frame was. Maybe into the frame just a bit. I am doing the same thing (static drop 2600 air bags) on my 2wd Blazer except I am doing all four corners. I am doing a notch just to be safe. I dont want to tear it all apart and find out I need to order one. I am thinking I might have to have the pass side notch modified as there is probably going to be interference issues with the relocated trac bar mounting hardware. I am doing this next week so I will post pictures as I go.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
Got L.E.D.s
Here's a pic of mine with the bolt in c-notch from CPP, with the bumpstops installed. The pumkin is just barly touching the bed floor.
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
