Old 07-26-2002, 11:58 PM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
Adjusting drum brakes
I just finished installing new drum brake shoes in my truck, correctly this time, lol. Anyway, how do i go about adjusting them so they work correctly? I know to stick a screwdriver through the hole in the drum and turn the little wheel over. How do i know if they are too tight or too loose? Any tricks to make this go faster? (i can't get at the adjuster hole no matter how i mount the wheel ).
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-27-2002, 12:12 AM   #2
Blue_71
Bloo
Blue_71's Avatar
what i usually do, is turn the wheel while adjusting until there is a slight drag.. but maybe youll have to take the wheel off and turn the drum? i cant figure out why you wouldnt be able to get to the adjuster hole
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-27-2002, 12:13 AM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
i always adjusted it tell they slightly rubed and made contact with the drums (not much contact, just slight)
68SWB4x4 is offline   Reply With Quote
Old 07-27-2002, 12:14 AM   #4
Josh
He's got mean nasty FANGS!
Josh's Avatar
What I generally do when adjusting my drums is, with the wheel off, adjust them one click at a time, till when I spin the drum, it will spin a few revolutions. Don't make them too tight, just tight enough to have a bit of drag on them.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 07-27-2002, 11:17 AM   #5
1-PU70
1-PU70's Avatar
Here is the best way I have found to do this in my 30 years of working on these trucks. First cut a hole in the backing plate where the star adjuster is. You can start with a drill then use a file or die grinder or even a drumal. Then with the drum and wheel on adjust the star till the wheel is locked. Then back off the star till there is just a very slight drag. You need to use a thin screw driver or a all to release the lock on the star adjuster.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 07-27-2002, 01:21 PM   #6
jhwkns
Registered Cruiser
jhwkns's Avatar
I'm lucky. I can reach the adjuster hole in the front of the drum through the slots in my wheels. this makes things real easy to adjust. I can do it from the front side without removing the rims.
When you replaced your shoes did you clean the backing plates, and lube the centering device? This is pretty important if you want you brakes to self-adjust properly. Also on vehicles this old it's always a good idea to replace the brake shoe springs, and retainers. The kits are cheap, and well worth the investment.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 07-27-2002, 02:49 PM   #7
basketcase
basketcase's Avatar
I agree with 1-PU70. Back when all we had was drum brakes the accepted adjustment was to tighten them until the wheel wouldn't turn then back them off 2 or 3 clicks. This is the only way you can be sure that they are all the same distance from zero clearance.
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 07-27-2002, 06:38 PM   #8
lukecp
lukecp's Avatar
Well, i got around to adjusting them today. Both were way too far in, and i had to turn the adjuster wheel to make them spread apart more. I turned it until i could start to hear the shoes dragging on the drums, and there was a little bit of resistance. The brakes don't feel quite like they used to, i'm guessing this is because the shoes haven't wore to the same contour as the drums yet. However, it dosen't pull one bit . I didn't add new springs and stuff, the old ones looked OK. I proably should though...i guess i can add that to my long list of stuff to do on my truck, lol.
Thanks for the help!
Old 07-27-2002, 07:46 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I like to use a little bit of anti-seize on the threads of the star adjusters.It doesn't always keep them freed up to where the self adjusters work but it does help.a dab of grease on the areas where the brake shoes rub the backing plates also helps them slide easier.
One thing often overlooked on these old trucks are the rubber brake lines. they are 30 or so years old so you might want to check them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-14-2015, 12:16 AM   #10
sharkskinman
Re: Adjusting drum brakes
I'm about to go the same
Had to replace driver front drum(cracked old one long story that ends in I'm an idiot! but I fixed it
Was wondering about the self adjustment..
Used to doing VW/Porsche ones that Don't self adjust
sharkskinman is offline   Reply With Quote
