Old 04-07-2005, 01:51 PM   #1
rusted75 half ton
More trusty Less rusty
rusted75 half ton's Avatar
Ignition removal help
I need to replace my ignition switch my first question is how do I remove it,I don't have the key but can turn it on with a screwdriver(I keep my title in the glove box beacause I can imagine what will happen if a police cruiser rolls up on me jaming a screwdriver in the ignition )next is do I have to worry about putting the steering wheel on"crooked"or does it go on only one way(idiot proof).
I've never done this before.Thanks
rusted75 half ton is offline   Reply With Quote
Old 04-07-2005, 02:01 PM   #2
Russell
Professional Grade
Russell's Avatar
Yes, it is possible to put the wheel on crooked. Just mark the base of the wheel / top of the column before you pull the wheel, and don't rotate the shaft after that
Keep an eye on where everything came, its not a difficult task, but there are a lot of little parts and peices that you can loose, or not put back in correctly Rebuilding my steering column was the very first thing I did on my GMC
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-07-2005, 02:33 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
http://home.t-online.de/home/O_Scholz/steering.html
I used this when I replaced my tumbler, turn signal switch, and lever. It is newer than yours, but it might be helpful.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-07-2005, 04:47 PM   #4
rusted75 half ton
Thanks for the response,mabey I'll take pics with a digital camera as I go
