04-13-2002, 08:42 PM | #1 |
Strange sound coming from rear wheel?
I have had this problem for a long time now and cannot pinpoint where the sound is coming from. It sounds like an ambulance siren only not as loud. It only makes the sound after I have driven it maybe 10 miles, like it has to get warmed up first. Could it be an axle bearing? Do they go bad often? It's a posi rearend if that helps. Please help me with this. It is embarrasing.
------------------ 72 c-10 lwb 350/4speed/3.73 posi
72 c-10 lwb 350/4speed/3.73 posi |
04-13-2002, 08:58 PM | #2 |
its all about the +6 inches
Are the springs that go around the drum in place?
(does a '72 have them at all??) ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-13-2002, 09:57 PM | #3 |
"Ochre Ogre"
Bearings don't usually sound like a siren. They will rumble, or growl. The sound you describe makes me think it is your ring and pinion gears. Does the sound go away when you let off the gas and coast? During a hard acceleration? Only at cruising speeds? When it makes the sound will help determine what is worn or out of adjustment. I read about this but really don't remember all the details. It had to do with the lash of the pinion gear to the ring gear.
A friends truck has a high pitch whine and it turned out to be a pitted ring gear. His truck is from AZ. It had sat for several years, probably in a hot shed. All the lube eventually came off and the exposed top half of the ring gear and it started to rust. All those little rust pits make that rearend sing. And I don't mean pfffft! ------------------ 1971 C-10 Suburban 1972 C-10 Suburban 1969 XL Galaxie Fastback 1968 Galaxie 500 Fastback 1974 SCOUT II Montrose, Minnesota [This message has been edited by da-burb (edited April 13, 2002).]
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
04-13-2002, 10:17 PM | #4 |
The drums on mine do not have any springs around them. The noise only starts up after I get up to around 15 mph. It does not matter if I am on the gas or coasting. Only after reaching a certain speed. It is not a constant whine but more like a pulsing sound. I have never messed with the posi rear but I will open it up and see what it looks like.
