Old 04-11-2005, 07:01 PM   #1
krue
Designated A-hole!
krue's Avatar
Question 72 cab on 70 frame questions
I finally got everything together and swapped cabs on my truck. I put the cab off a 72 on my 70 frame. 2 questions immediately arise.
1. What do I need to get for my carb to get the throttle cable (instead of rod) hooked to the carb.
2. My gas tank has only a single line coming out the sending unit to fuel the engine. The new tank has 2 lines coming out and 3 going thru the cab floor. What do I hook up, what don't I or would it be easier to just put my old tank in there?
Now to the good part, the pics.
First I got the donor cab ready to come off. Then I pulled the inner fenders, grill, front bumper, fenders and hood off of my truck.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 04-11-2005, 07:08 PM   #2
krue
Designated A-hole!
krue's Avatar
Then pulled the cab off my truck with my younger brother's help. Had to get someone a little more nimble than my fat a$$ to hang the chainfall out of the tree.
www.daveramsey.com
Old 04-11-2005, 07:10 PM   #3
krue
Designated A-hole!
krue's Avatar
Finally dropped the new cab on my frame. Made a few connections, the rest will
have to wait til tomorrow. Not too shabby for a hard days work.
www.daveramsey.com
Old 04-11-2005, 07:20 PM   #4
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
That's a lot of work for a day.Looking good.
The big line is the supply,one is return,and one is a vent I think.You could just swap the sender
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-11-2005, 07:29 PM   #5
krue
Designated A-hole!
krue's Avatar
BTW I would like to say without my Makita cordless impact I would still be laying in the dirt!
www.daveramsey.com
Old 04-11-2005, 07:49 PM   #6
incoma
incoma's Avatar
Great job. Now if the rain would stop so you can finish the job!!
Looks like you've got extra parts now too!
incoma is offline   Reply With Quote
Old 04-11-2005, 07:57 PM   #7
krue
Designated A-hole!
krue's Avatar
Yeah, but I have a blazer that needs mucho metal!
www.daveramsey.com
Old 04-12-2005, 05:31 AM   #8
Lookin good Krue. Hope the weather cooperates for you today to get more done on it.
Old 04-12-2005, 07:20 AM   #9
dtlilly
dtlilly's Avatar
Looking good Krue! When your done with yours, fill a couple coolers full of live mudbugs and head up here.
My C-30 will look like that in about 2 months from now.
As for your throttle, can't you pull your pedal assembly out of your old cab and install it in the new cab? I think it all un-bolts, except for a bracket that is welded in.
The fuel tanks should swap out too. I'm actually going to be using a pre-evaporative emision control tank in my 72, because I can't find a good clean 72 tank.... oh, wait... your coming up here... will there be room for the tank next to the mud bugs
dtlilly is offline   Reply With Quote
Old 04-12-2005, 12:36 PM   #10
barn9
Half a bubble off!
barn9's Avatar
Lookin' good Krue!
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 04-12-2005, 04:20 PM   #11
flip66
flip66's Avatar
For the carb you will need the bracket that goes on the carb to hold the throttle cable, kind of like the TH350 trans kick down cable, and the little ball that bolts to the arm of the carb and clips to the end of the cable. Most auto parts have the bracket in the custom chrome parts section and the ball in the help section
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 04-12-2005, 04:38 PM   #12
dtlilly
dtlilly's Avatar
Maybe I'm misinterpreting things here... Krue has all of that originally on his 1970 GMC. He has swapped a 1972 cab. He will need the hook-ups to his throttle and carb. I think he can transfer his 1970 linkage to the 1972 cab and run like he has every day with out any problem. The deal is that his year uses a cable hook-up and 1972 uses a linkage hook-up. He should be able to convert the two, and get the 1970 with the 1972 cab he installed.
Old 04-12-2005, 05:02 PM   #13
flip66
flip66's Avatar
I thought he took off a 70 cab put a 72 cab on. If that is the case the 67-70 rod style throttle will not work in a 71-72 cab without modes the pedals are in different locations on the fire wall. 67-70 has cut out for the rod and the 71-72 has a small square hole for the cable. If it is a 72 cab the easiest thing to do would be get a 72 pedal and assembly and us it.
Old 04-12-2005, 05:12 PM   #14
dtlilly
dtlilly's Avatar
Ahhh yes, I was messed up on cable and linkage between the years, makes me show my memory loss...
Why couldn't krue just transfer everything he is using in the 1970? Holes and linkage should not be that hard to transfer or fabricate.
Old 04-12-2005, 05:38 PM   #15
cableguy0
i did almost the same swap the base truck was a 72 and i used a 69 cab. i used my tank from the 72. i dont use the return because im not running a stock fuel pump but i used the vent tube and what not that was in the b pillar on the 72 cab. i decided after a few beers that i would be much easier to just use the pedal and rod assembly from the 69 i just had to tweak the rod a bit to have it hook up to my carb
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-12-2005, 08:38 PM   #16
krue
Designated A-hole!
krue's Avatar
Don all I have to do is bolt a little ball for the cable to clip onto my carb. I want to stay with the 72's hanging style gas pedal becuz my 70 pedal has to have the balls on the floor to mount to. Currently I don't even have a pedal for it...well I didn't until I swapped cabs.
www.daveramsey.com
Old 04-12-2005, 09:00 PM   #17
So did the weather cooperate for you tiday Krue and you get er done...or at least looking like it is a truck.
Old 04-12-2005, 11:33 PM   #18
krue
Designated A-hole!
krue's Avatar
I have the front cap (minus inner fenders) back on, hopefully I will feel like finishing it when I get off work in the morning.
www.daveramsey.com
Old 04-13-2005, 08:04 PM   #19
krue
Designated A-hole!
krue's Avatar
Well I finished hooking everything up this afternoon and other than the bumper and inner fenders I am done. Drove it to work tonight, after adjusting the rod between the brake booster and the m/c everything works good. It's a lot quieter in the cab now, not nearly as much wind noise.
Did find another difference in the cabs, I don't know if it is due to the difference in years or between a/c and non-a/c cab, but the screw in the firewall that the ground strap from the engine hooks to is about 2 inches higher on the 72 non-a/c cab than on the 70 a/c cab.
www.daveramsey.com
Old 04-13-2005, 08:10 PM   #20
Congrats Krue. When does the bed go on?
Old 04-13-2005, 08:33 PM   #21
krue
Designated A-hole!
krue's Avatar
Probably gonna be a while, gotta get a lot of stuff done first. Here's some pics of her I took today.
www.daveramsey.com
