Old 04-13-2005, 06:30 PM   #1
3quartertime
My Mistress the Sea
3quartertime's Avatar
Power Steering gearbox replacement
Hi all,,,
I have what I think is a power steering gearbox going south really quick. The truck is wandering badly on the road. I have a few direct questions...
Can the power steering gearbox cause instant failure? For example if I'm on the highway will it totally fail and I crash and die? Drastic I know but the truck is whipping around pretty bad with the trailer attached. Tongue wieght isn't an issue as it does it unloaded and rides pretty flat.
For a replacement should I go with a rebuild unit or a new one?
I searched and found
this
about the summit aftermarket one. What would be the difference? I read my maintenance manual and I believe it states that my truck has a varible gearbox now. Would I notice a big difference like a 1970 truck owner would?
Truck is:
1971 K20 350/350
Thanks!!!
,,,they'd look alot better as beer cans...
'71 K20 350/350 Rusty but trusty... gone
'70 C20... gone
'88 K1500... gone
'90 C1500... gone
'91 C2500... gone
'95 C3500 6.5L Dually love this one!...
3quartertime is offline   Reply With Quote
Old 04-15-2005, 08:41 PM   #2
3quartertime
My Mistress the Sea
Still hoping for some help...
Updated info is that the steering seems to be less loose during a longer drive. Not totally gone, but less sloppy. I've checked the fluid level several times and it's good.
A question about the adjustment on top of the gearbox.
I've been told that this adjustment can really help wandering problems. But you can go too far and cause problems. I understand that you loosen the lock nut and adjust the allen head part. Anyone have any pointers on that part???
Thanks!!!
'70 C20... gone
'88 K1500... gone
'90 C1500... gone
'91 C2500... gone
Old 09-28-2005, 06:19 PM   #3
matthufham
is it just losing fluid through a broken seal, or is something wrong with the gears in there? fluid leaks won't cause a crash.
matthufham is offline   Reply With Quote
Old 10-01-2005, 12:23 AM   #4
_Dick_
PROUD TO BE A MEMBER
_Dick_'s Avatar
I have the same problem ,after to many hours and one pitman arm later i am sure i need to replace steering box .i have about a 10 degree slop in my power steering and it drives my crazy .heres a couple places to read more i have found hope, they help you.
http://www.classicperform.com/tech.htm http://www.discountsteering.com/
http://www.google.com/search?hl=en&q...=Google+Search
_Dick_ is offline   Reply With Quote
