1970 K10, 350, 4spd!
Glovebox/CD player Installed *Pics*
Well not many commented on the glovebox I had made. I am very happy with the way the box turned out. Here are some pictures of everything installed. It wasnt as cheap as just cutting a hole in the dash but in 30 mins I could have the truck back to stock
![]() P.S. Yes, I know I forgot to connect the drivers side vent hose back up. While I had everything torn out I cleaned and wiped down all the duct and the inside of the unit that hangs down below the dash. |
Super clean install man! Looks great. Improvement without defacing the OldSkoolness of these fine machines.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
![]() ![]() Join Date: Jul 2002
Very nice. Does it have a remote or do you have real long arms (like me)?
That was one of the requirements of the cd player. I bought one with a remote.
Looks very nice, I'm going the same route (glovebox), just waiting for the head unit to arrive in the mail. I still am undecided on where the speakers are going though.
#6 | |
You stole my idea! I've wanted to do that along with put a bunch of extra guages, torque converter lockup control, data aquisition link (way down the road). What did you make that box out of? Did the radio have clearance problems with A/C box? Same as you again I want to put the speakers down on the floor so I don't cut up the cab. I'd like to see some pics if/when you get started on that.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
will the remote get through the glove box door? or do you have to drive with it open??? ;-)
'06 silverado (daily driver) '02 nissan sentra (wal-mart warrior) |
#9 | |
ZOIE AND ZACK
man that looks good super clean!! any reason you chose right hand corner of glove box? most of the ones i've seen are in the middle. are you going to mount any thing else next to it? do you have any pictures of speaker bracket you made.
AMERICAN BULLDOGS AND CHEVY TRUCKS 71 1/2 SUBURBAN 402BB IN PROGRESS 90 1/2 TON SILVERADO 02 1/2 SUBURBAN 67 GMC 1/2 TON LONGBED 05 AVALANCHE |
F.A.S.T. president
![]() Join Date: Sep 2003
thats a very clean job
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
#12 | |
I was actually looking this evening and I might attempt to make a bracket that is slighty below and setback from the face of the dash, that would hold (2) 6 1/2 speakers. I like making things out of wood! hah, my grandpa was a woodshop teacher for years and years. He has an airconditioned wood working shop that is about the size of my house. |
#13 | |
ZOIE AND ZACK
how about that speaker bracket any pics??
#15 |
I still need to get the speakers, I'm looking at Pioneer's TS-D601P (6.5") & TS-D901P (6X9). How did you install the wood bracket for the 4" Alpines? Did you use the 2 factory bolt holes for the original speaker bracket and brace them in another spot also? The box idea (on the floor) is a good one. I've thought about installing 2 6.5" in the kick panels & 2 6 x 9's in the doors using baffles and dynamat but I gotta admit I'm pretty "chicken" about getting the jigsaw out (lol), I may go with pods (kickpanel)for the 6.5's and the box idea for the 6X9's (using fibreglass).
#16 | |
Do you think the radio would fit in the top left corner instead of the bottom right? I had my plans with gauges lined across the bottom and radio uptop for looks. Just curious.
#17 |
![]() Join Date: Feb 2000
I've never seen a a/c equipped truck's glove box to know how limited they are in size. Your setup looks real nice. Is there extra space that could be used to hold cd's in the glove box if the box you made was modified.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#18 |
No,I DON'T have Tourett's
Nice install. I did the same to mine. Keep us posted on the IR repeater thing. Also, I found I had to install a little fan in the glovebox to keep the unit cool. I put an antennea splitter on so i could run cd receiver and stock am radio off same antennea.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
#19 |
Looks really nice! Great job.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
#20 | |
#21 | |
Overall the glovebox width is around 18 1/2". On an A/C truck the A/C riser eats up 7 inches from the drivers side of the glovebox towards the middle. That leaves you around 11" to work with. I dont know exact measurements from the top of the glovebox to the firewall but I would guess its around 5". My cd player is 6 1/2" deep so it would have no chance to fir in the top left corner. Maybe if you removed your glovebox door and built the glovebox more shallow than mine which was 2 1/2" you might be able to fit a cd player in the top left of a non-a/c cab. More than likely the cd player would have to stick out a little past the front of the dash to fit. |
#22 | |
#23 |
KEEP ON TRUCKING
nice and clean
72 cheyenne 2wd lwb 71 k20 sons bassett va |
#24 |
Very smooth! Now you just have to take the remote receiver out of the face plate and
mount it down below so you can keep the door shut! J/K Good job. |
#25 |
71 Cheyenne SWB Fleetside
where is the repeater you were talking about?????
Joel
