Old 04-14-2005, 02:34 PM   #1
Jesse72
Jesse72's Avatar
4spd to turbo 400?? Help
Will a turbo 400 bolt right into my truck if it has a 784spd in it now?? If so would I be able to run a ratchat shifter w/ a 2in body lift??
Jesse
72 4x4 Sold
59 GMC air ride ls swap
Jesse72 is offline   Reply With Quote
Old 04-14-2005, 03:13 PM   #2
1969 GMC
1969 GMC's Avatar
No. I am guessing you have the NP205 since you didn't say. If thats the case you will need the TH400 to NP205 adapter, which is $$ if you can even find one, from a 77-84 K30 1 ton truck. Then you will need a 32 spline input gear for your transfer case, about $150, and then have the bearing hole bored out for the larger bearing, around $40-50.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-15-2005, 04:55 PM   #3
Jesse72
Jesse72's Avatar
will a turbo 350 or a 700r4 fit??? and yes i have a 205 o and it is a 72
Jesse
72 4x4 Sold
Old 04-15-2005, 06:01 PM   #4
justinf
No, I believe your 205 is a 10 spline version, so you will need to find the correct adapter, and input for any tranny you want to install.
Or just find a TH400 with the transfer case and correct adapter, and then sell yours.
Yes you should be able to use a ratchet shifter with a 2 inch body lift.
1981 CJ7 - 350TBI, sm465, np205, D60, 14bolt, 5.13s, detroits, 38.5 SX's
1998 Z71 extended cab
1998 Tahoe
2001 Tahoe LS - FOR SALE - $18,500
justinf is offline   Reply With Quote
