Old 04-18-2005, 12:25 PM   #1
Paso76GMCstepper
Paso76GMCstepper's Avatar
Drivetrain Questions Gears and stuff!!!!
Ok I have a 76 GMC K15 350/SM465/NP205
I have a GM 12 Bolt in the rear. I took the cover off yesterday to change the gasket and change everything to Synthetic Gear Lube.
I know its limited slip but does someone have a site I can look up pictures for this rear end. Can there be different limited slip set ups in this rear end??
Also It has a DANA 44 front end. On the tag it says its 3.07 gears. So this is pretty high geared for a 4X4 Truck. If the front is 3.07 then the rear is the same right?
I am regasketing and sealing the trans and T-case so I am putting Mobil 1 Synthetic 90 gear oil in everything. All new ujoints, clutch and everything.
Tony
"Life is a Team Sport"
To the memory of the Hendrick Motorsports Plane Crash Victims
Paso76GMCstepper is offline   Reply With Quote
Old 04-19-2005, 12:22 AM   #2
79C10
yep front amd rear axels are the same.
79C10 is offline   Reply With Quote
Old 04-19-2005, 07:07 AM   #3
Blazer1970
Blazer1970's Avatar
I believe that by '76 GM was using the Eaton locker (Gov-lock) as the factory option (G80) in the rear.
Blazer1970 is offline   Reply With Quote
