Old 04-21-2005, 04:35 PM   #1
67chevemall
67chevemall's Avatar
Setting up new carb! first start?
Yello!
I have everything together for the first start of the season!
My ? is I have a rebuilt carb on there that is going to need setting up,
should I take the Ign. wire off the dizzy so it won't start to get
fuel to the bowls. Then set the bowls or just start it and set things up?
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-21-2005, 04:56 PM   #2
Jason915
the bowl will fill up fast enough just crank on it and pump it a few times while cranking.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 04-21-2005, 06:01 PM   #3
COBALT
COBALT's Avatar
What kind of carb is it?
Bolt it on, set up the vacuum lines, give the accel pump a couple of pulls until gas starts comming out of the jets under the venturis, and fire it up.
Done.
After that it's just a function of adjusting idle, mixture screws, accel arm, etc. You also may have to check for leaks around any mating surface (carb-to-intake, airhorn assembly, fuel leaks, vacuum lines, etc.).
If you're one of the unlucky ones who has a fuel pump that isn't putting out the pressure the carb wants it could cause problems, but don't worry about that until you're forced to deal with it. Some mechanical fuel pumps overwhelm the floats and you can flood your truck.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 04-21-2005, 11:16 PM   #4
67chevemall
thats what was happening to my temp. carb among other things. Now I have
a fuel reg. and fuel psi gauge with the old rebuilt holley back on. Everything helps.
Old 04-25-2005, 10:12 AM   #5
sargentjones
BOLT SMASHER
sargentjones's Avatar
jUST PUMP N START. nOTHIN TO IT..CHA BAM!
Jeff
73 Chevy C-10 350 4-Speed
RUST DON'T WAIT FOR NO ONE......
sargentjones is offline   Reply With Quote
Old 04-25-2005, 10:36 AM   #6
67chevemall
Sargent I tryied that but can't stop the fuel from pouring into the carb
The pri. bowl is set good but the sec. bowl seems to just keep on pouring.
