Old 04-26-2005, 05:17 PM   #1
joelboxt
71 Cheyenne SWB Fleetside
joelboxt's Avatar
Arrow Single piece drive shaft.
does anyone know if there is a single piece drive shaft out of a newer truck that would fit a SWB 71 truck with a TH350 engine? dont want to pay loads to have one made. will have to change the yoke im sure. but is there any other option then having one built?
thanks
joel
joelboxt is offline   Reply With Quote
Old 04-26-2005, 05:26 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Need some more info. What happened to your driveshaft? Is it a two piece? I was under the impression SWB trucks all came with a one-piece? Did you use something other than a GM rearend? If you need your driveshaft shortened, I had mine done for $15 at a local shop. If you need it lengthened, I see your dilemma. Go to a 'yard and start measurin
Edit, when I put a 700R4 in my truck I had to find an automatic splined shaft so I thought, why not try to find one that will already fit, not sure on your tranny lenght, but trips to 3 yards didn't come up with a match. I ended up adding the automatic yoke and takin it to a shop.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-26-2005, 05:54 PM   #3
CHEVYE
my gas saver
CHEVYE's Avatar
thanks
joel
i believe they made both, at least i've had em with both (assuming it's a swb), i have 2 of them in the garage, and i see them on here for $50 to $75 all of the time for a th350 trans.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 04-26-2005, 06:05 PM   #4
joelboxt
joelboxt's Avatar
hey Redneck,
the one in the truck is a two piece unit and the hanger bearing is toast. so i just thought maybe i will get a single piece, rather go that route. its the standard 12bolt truck rear end. TH350 with a 350CI engine. on a SWB fleet side truck.
Chevye, are you looking to sell one of those single piece units you have there? if so, how much and pics?
i thought maybe i could go with a SWB newer style truck with those aluminum ones?
joel
Old 04-26-2005, 08:04 PM   #5
CHEVYE
my gas saver
CHEVYE's Avatar
i can't sell mine, i need em. i know "suicideD" had one for around $50 or so. just put a wtb ad up and i'm sure someone will reply. i have had driveshafts done for v8 s10's before for around $140. it would probably cost $100 to ship one from here to there anyway.
check with "billsbowtie" also, i got both of mine from him. he always has a ton of parts.
71`SWB, project
ebay feedback
Old 04-26-2005, 08:06 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If your engine and tranny are installed in teh proper location on the frame, the drive shaft will need to be 4 foot 10 inches....first gen Camaro/fire bird (F body) had the same, and that would make me wonder about the 78 - 72 ( I think I got the years right) Nova and clones (X body) since the under pinnings were pretty much the same.
Old 04-26-2005, 09:41 PM   #7
joelboxt
joelboxt's Avatar
thanks guys,
im going to put up a wanted add for now i guess see how that goes.
how does that work now, with a single shaft when your rear suspension moves will there be enough room in that centre cross member where the shaft passes through? worried about it hitted the top of it if you hit bumps or something?
let me know.
joel
Old 04-26-2005, 09:50 PM   #8
joelboxt
joelboxt's Avatar
longhorn, a newer short box truck shaft wouldnt fit eh?
joel
Old 04-26-2005, 09:57 PM   #9
joelboxt
joelboxt's Avatar
joel
Old 04-26-2005, 10:55 PM   #10
Longhorn Man
no clue Joel. Never had to measure one. I wouldn't do the late model ones though becouse the stupid GM U-joints pretty much blow, and the replacements never seem quite right...you have to drop the shaft to lube it...so it never gets lubed.
Old 04-27-2005, 04:47 PM   #11
joelboxt
joelboxt's Avatar
alright thanks for you help
joel
Old 04-27-2005, 05:05 PM   #12
67ChevyRedneck
I have never seen a swb with a two piece. Interesting. I'd call around to some local yards to see if they have a one piece. As far as I know you shouldn't have any problem with the center section hitting the shaft unless yuor truck is seriously lowered. Make sure it's for an automatic and you may have to still measure, I think some tranny's were different lengths back then??
Jesse James
Project "On a Dime"
Old 04-27-2005, 08:13 PM   #13
SB_in_SC
'68 C10 SWB/FS 396/TH400
SB_in_SC's Avatar
FYI, my '68 SWB/FS 396/TH400 has a two piece shaft.
'68 Custom/10 w/396/TH400 matching #'s
'00 C3500 Dually 454 Crew Cab
'99 Chevy Tracker 4x4 (1 tuff little muther!)
SB_in_SC is offline   Reply With Quote
Old 04-27-2005, 09:21 PM   #14
joelboxt
joelboxt's Avatar
two piece sucks, thats why i want to chang mine. the hanger keep going.
Old 04-27-2005, 09:43 PM   #15
CHEVYE
my gas saver
CHEVYE's Avatar
hey joel, i'll measure one in the garage when i get home if you need me too. it might help you out looking for one.
71`SWB, project
ebay feedback
Old 04-27-2005, 09:53 PM   #16
RODSBYT
RODSBYT's Avatar
1 pc. driveshaft
I used one from a 1966 Chevelle.
I had a custom one made for my 66 chevelle from dennys driveshafts.
The original one from the chevelle was a perfect fit in my 71 short bed
with turbo 350.
The chevelle is a big block with muncie 4 speed.
Much smoother and quiter than the 2 pc. shaft.
RODSBYT is offline   Reply With Quote
Old 04-27-2005, 10:21 PM   #17
Longhorn Man
One thing to remember...a properly ballanced drive shaft, with all the u-joints and carrier bearing installed properly, will not only last for many years, but will hold up to gobs of power. If it is time to redo everything...all the joints and bearing, then it may be a good time to replace it...but IMO, it is a bit of a waste of $$ to replace the assembly when nothing is wrong.
I only say this becouse WAY too many ppl think that a 2 pc shaft is unsafe or a maintnance nightmare.
Old 04-27-2005, 10:56 PM   #18
joelboxt
joelboxt's Avatar
chevye, i would appreciate it.. let me know.
thanks,
joel
Old 04-27-2005, 10:57 PM   #19
joelboxt
joelboxt's Avatar
longhorn, i dont think they are unsafe. but the hanger bearing is toasterd so id like to maybe lose the two piece.
joel
Old 04-27-2005, 10:59 PM   #20
Longhorn Man
Chevye...the one from the GMC is 4 foot 10 inches...the rear U-joint is a couple years old, front one is pretty old.
Old 04-27-2005, 11:38 PM   #21
RIDDLA
RIDDLA's Avatar
i used a one from my 86 chevy caprice with 700 tranny still have it on there Riddla
68 GMC-Stripshow
70 Chevy Monte Carlo
72 Chevy Monte Carlo LOLO
72 Chevy Suburban Blurban
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
03 Cadillac Escalade-Duecesix
84 Cadillac Coupe Deville DeElegance
B.O. A Lifestyle Money Cant Buy!
Win,Lose, or Tie
I'm a Raider till i die
RIDDLA is offline   Reply With Quote
Old 04-28-2005, 07:32 AM   #22
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
I do have one, but mine was with the v-8 in the six cylinder position. Might not work for the standard configuration. I had to go look at my for sale page to remember how much I was asking.... I'll take 75.00 plus shipping.
http://www.suicided.com/forsale.htm
Thanks ChevyE for pimpin my stuff.... got a door skin installer I'll let you push also.
Suicide-D is offline   Reply With Quote
