04-27-2005, 09:13 AM | #1 |
WTB-Throttle Body for my 87
like the title says, i need the throttle body for my 87 with the 305....my throttle body spring is sooo damn tight, its gettin on my nerves...
need one that moves alittle more easily..... (i got to mash on the gas to get it to go...its not like a carb set up where you can pull the throttle return spring some to get a softer pedal, this spring is internal)
1987 350 TBI lowered 5/7 |
04-27-2005, 01:05 PM | #2 |
Certified Truck Nut
can you use one from a 350? i have a friend that tore down an 87 TBI 350 and the throttle body is just sittin in the back of his outbuilding. lemme know if you can use it and ill hook ya up!
later Dan
1982 GMC Sierra Classic 1500 Longbed 350, TH350, 3.73 10 bolt soon to be slammed |
04-27-2005, 05:29 PM | #3 | |
i'm thinkin there the same, except for the size of the injectors....does anyone know this for sure? i'm pretty sure there the same...(but not 100%)
04-27-2005, 07:00 PM | #4 |
www.73-87chevytrucks.com
Same throttle body, different injector size. If memory serves me correctly it was 18lb @ 36PSI for the 305 and 24lb @ 43.5 PSI for the 350
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
04-27-2005, 08:22 PM | #5 |
Certified Truck Nut
so you want it? i'll hook ya up!
later Dan
04-27-2005, 09:13 PM | #6 |
Oh,you can't buy that new
Kumar, Mike broke several throttle cables and two gas pedals in that truck . is the throttle body the ONLY reason why ? DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
04-27-2005, 10:16 PM | #7 |
I had a truck that had the same symptoms as yours .I cleaned the inside of the throttle body and found out that it was just the throttle blades sticking . On another truck I had to lubricate the inside of the throttle cable . I had to disconnect it and stretch it so that the lube ran down the inside of the cable . Just something to check if you havent already . Frank
04-27-2005, 11:12 PM | #8 | |
yeah, i'm pretty sure....it needed a tune up real bad, but it now runs like a smacked ape! (well, a tired 305 smacked ape ) it just acts like (in a carbeurated motor) the throttle return spring is too tight......i'm sure that the return spring is internal, so there's not much to do with adjusting it (at least i dont think so) i'd like to try another tbi, to try and see if that cures it
04-27-2005, 11:16 PM | #9 | |
i just now read the whole post you wrote (didnt see it all before) he broke several throttle cables?...how the heck is that accomplished???? ...and two gas pedals?...geeesh....it aint all that stiff i got it lowered now, with 3:42 posi rear ...but, ya got to remember though...."mike" didnt even know where the rocker panels were...so he's not too "mechanically inclined"...i'd imagine some mechanic somewhere could have easily persuaded him into buying pedals, and cables... ...maybe even some "canadian air" for his tires
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 04-27-2005 at 11:17 PM. |
04-27-2005, 11:47 PM | #10 |
" i'd imagine some mechanic somewhere could have easily persuaded him into buying pedals, and cables"
No I didn't persuade him---- he asked me for one when his broke. I had recently parted out two K5's and always seem to have what he needed and delivered to work for Cheap$$ . i know he bought one cable from me and two gas pedals and put another gas pedal in it from a boneyard right before you got it. those 3.42's make a big difference to those 305's . Mike was tough on the $$ for the truck. it KILLED him to put that $$ engine in ,but was pretty faithful after that. He just had work done from a local guy to the front brakes also. Find me a 73-74 -75 1/2 ton for way cheap will ya. DAVE
04-28-2005, 07:36 AM | #11 | |
i didnt know he "jewed" you into workin on the truck ....he was tight wasnt he?
