Old 04-27-2005, 11:44 AM   #1
GasHog396
Question New workshop, now I need a lift.
Hi all, it's been a while since I posted to the board. New house, new wife (Apr 16th), and now a new 2400 sf workshop (finished yesterday) have kept me pretty busy. Now that the workshop is done, I know that I want to get a lift to put in it, but can't decide on a two or four post model. One of each would solve the problem, but not enough $$$ right now. I had a portion of the slab poured 6" thick, so that's not an issue, and there are two bays with 12x12 doors (one a pull through). I'm thinking of either a 8000 or 10000 lbs capacity so I can lift a pickup (neighbor's Dodge is over 6800 lbs), or maybe a Class-C motor home if I get one in the future. Do any of you have any experience with these lifts, and what are the pros and cons of each type? The major benefit for the two post that I see is, you have a clear undercarriage. Let me know your thoughts.
Thx, Ted C.
'67 1/2 Ton Short Bed / 396 cid / AC w-R134a / 5 Lug Leaf spring rear axel / 5 Lug Frt Disk Brake Conversion
'97 Trans Am - Black / LT-1 / K&N FIPK Cold Air Kit / Hooker Cat-Back Exhaust / 160 Thermostat
'02 Buick Regal GS / Bone Stock
GasHog396 is offline   Reply With Quote
Old 04-27-2005, 12:17 PM   #2
70 shorty
Where's my beer?
70 shorty's Avatar
All I can say is DAYUM, I wish my HOUSE were that big, much less the garage.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 04-27-2005, 01:52 PM   #3
rambler
MOVE OVER
rambler's Avatar
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 04-27-2005, 03:37 PM   #4
GasHog396
ok, ok, I get the subtle hint , I'll get some pics taken and posted tonight or in the morning. Won't be able to do inside pics as electric isn't hooked up yet.
Old 04-27-2005, 04:07 PM   #5
moneyguru
moneyguru's Avatar
Well the wife and I have been looking around for our next house, something with a pole barn or space to build one.
Long story short, we've found a house that is a SERIOUS fixer upper, can you say gut? The fun part is that yes it does come with a pole barn, it's a little small for my taste (insert snicker here) at 40 x 120 feet which = 4800 Square feet!
Just thought I could share that little info with you guys here, I don't think anyone in my fmaily would understand the fun of having that pole barn!
"Do the things you fear to do and the death of fear is certain"
moneyguru is offline   Reply With Quote
Old 04-27-2005, 04:11 PM   #6
rambler
MOVE OVER
rambler's Avatar
oh yeah,, pics of the shop as well I would go with a 2 post (my shop ceiling is too low) :cry: not sure how much weight they can hold, awhile back there was some very good discussion on lifts on the site..
Buckaroo Banzi
Old 04-27-2005, 05:04 PM   #7
joelboxt
71 Cheyenne SWB Fleetside
joelboxt's Avatar
go with a two poster.
joel
joelboxt is offline   Reply With Quote
Old 04-27-2005, 06:54 PM   #8
Kid
Kid's Avatar
two post
Kid is offline   Reply With Quote
Old 04-28-2005, 04:25 AM   #9
4x4Poet
If, by four post you mean you drive the rig onto it, and, by two post you mean you drive the rig between the posts and swing in arms under the frame/body, then:
The two post is best for tire removal, brakes, axle housing swaps, and suspension work, as well as for removing bodies from the frame. The four post is good for driveline work and pretty much everything else. Also, some 4 post lifts can store a vehicle in the up position so another can be driven under to save space.
Edit: I'd consider the 4 post first because it would be larger and require more placement planning. Unless you plan to swap some cabs/bodies, jacks and stands can substitute for a two post fairly well. Speaking within my understanding of 2 & 4 post lifts, of course.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 04-28-2005, 06:38 AM   #10
Dean
Dean's Avatar
I went with the 2 post Dover Rotary 10,000 lbs. I can store a car on the up position with it also. You just let it down on one of the stops. I'm very happy with it so far.
Dean is offline   Reply With Quote
