Old 04-27-2005, 08:43 PM   #1
cobb_ben
cobb_ben's Avatar
What's the best way to cut the dash for Modern Radio??
I was wondering how you would cut the dash out to make the radio hole large enough for the modern box radio, I think that is called a DIMM?? The common aftermaket size. Also how do you remove the dash bezel with the hole for the light switch being to small??? Because like on my 1976 the hole is bigger that the knob on the light switch. Thanks guys any advise would be appriciated.
Ben
cobb_ben is offline   Reply With Quote
Old 04-27-2005, 09:06 PM   #2
raceman6135
Dino burner
raceman6135's Avatar
Most people use a Dremel, or an angle grinder with a thin "cut-off" wheel, or a jigsaw to cut the hole to the proper size. Remember: measure twice, cut once!
You have to reach under the dash to the light switch, where you'll find a small button. Push and hold the button, and then pull on the light switch knob. The knob and shaft should pull out of the switch, allowing you to remove the dash bezel.
Darrin
raceman6135 is offline   Reply With Quote
Old 04-27-2005, 11:38 PM   #3
bodydropped
the stero installer put the radio holder on my dahs and marked it then used a solder gun that had a flat peice and use that to cut the plastic he took his time and it looks like a factory job installed
bodydropped is offline   Reply With Quote
Old 04-28-2005, 08:04 AM   #4
bringit
I used a air tool with a thin cut off wheel, but a dremel would work great also. My advice is to cut the hole to small first (inside the lines) and slowy trim till it fits tight.
85 chevy K10 350 crate, headman headers, street avenger carb, accel distrib , rebuilt 700r4, on 33" Super Swamper TSL's, 4 inch Pro Comp lift, shocks, and steel braided brake lines.
bringit is offline   Reply With Quote
Old 04-28-2005, 08:35 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I have a tool you can borrow. It works pretty good if your easy on the trigger....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-28-2005, 09:22 AM   #6
badassbowtie81
you laugh i used sawzall on mine....looks really good actually
badassbowtie81 is offline   Reply With Quote
Old 04-28-2005, 10:00 AM   #7
screwballl
Tonawanda 454
screwballl's Avatar
a reciprocating saw sometimes is the only way to get a proper cut on these...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 04-28-2005, 10:38 AM   #8
Greenlee
Greenlee's Avatar
Alot of them I have seen done by other people have a gap showing where the big square opening is for the factory radio. If you are careful you can avoid that. Mine looks like a factory fit. I marked the hole using the metal sleeve that holds the radio and used an air die grinder with a thin cutting wheel to cut the hole.
If your 76' is like mine (also a 76), you don't need to remove the light switch to get the bezel off. I have seen the bezels with a really small hole, and I guess on those you would have to remove the switch for the light. I think the small hole bezels came on early models (possibly 73-74???).
Greenlee is offline   Reply With Quote
Old 04-28-2005, 11:01 AM   #9
bringit
If you use a resiprocating saw or jigsaw you will rattle loose everything in the dash. Use a rotory tool like a dremel or air tool and you will get better results.
Old 04-28-2005, 11:42 AM   #10
Ric83
Ric83's Avatar
We just used a hacksaw blade when we did my dad's.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 04-30-2005, 07:50 PM   #11
1985K10
1985K10's Avatar
I used a Dremel and a hacksaw blade.
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 05-01-2005, 10:38 AM   #12
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
ive had great success cutting almost anything with a dremel. ive invested in a extension tool thats flexible that works wonders god i love that tool!!
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-01-2005, 02:45 PM   #13
75Chevy90Kawi
the green machine
75Chevy90Kawi's Avatar
the dremel is the best tool ever. i use mine about 20 billion times a day. i would imagine a cutting wheel would be hard to get in the right place though because of the angle and the fact that the blade is a lot smaller than the diameter of the actual dremel. but i didnt do mine, it came with it
1975 Silverado - 450 horse crate 383 stroker, 20" Centerlines, Flowmaster exhaust, Hooker headers, full MSD ignition & more...
2003 Suzuki TL1000R
1985 Kawasaki JS550 hull - project ski - WILL have - 650, footholds, custom paint, 4* bars, bilge setup, and more...
My pictures
75Chevy90Kawi is offline   Reply With Quote
Old 05-02-2005, 02:37 AM   #14
gregbr
Senoir Member
gregbr's Avatar
Just did it on my son's 85 K10, looks very similar to 1985k10's picture above. Our Pioneer had the same trim and all, we ended up with the trim flush with the plastic part so the dash panel can be removed without removing the radio. The dremel tool and small cutoff discs worked great.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 05-02-2005, 02:56 AM   #15
C-10volvo
C-10volvo's Avatar
i used..... a jig saw.... but i built something. i dont like cutting up the dash. food for thought
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 05-02-2005, 10:00 AM   #16
cobb_ben
cobb_ben's Avatar
I liked the box, and I just ended up cutting the dash, is is kind of close, some gap in there but it wil be ok.
Old 05-07-2005, 11:18 PM   #17
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
I used a sawzall to cut the metal dash part and a dremel to cut the plastic bezel.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 05-07-2005, 11:25 PM   #18
Russell
Professional Grade
Russell's Avatar
Personally, I'd pick up a factory radio delete plate, and install the radio into that. It removes the possiblity of an unsightly gap that sometimes happens if you don't cut it perfectly.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-08-2005, 12:09 AM   #19
'78 Fleetside
Young'n
'78 Fleetside's Avatar
Thx guys, i was about to come here and ask the same exact question haha, and 1985k10, i have that EXACT deck lmao, but its only temp. =D i got big big plans. Well thx again guys for you help.
'78 Fleetside is offline   Reply With Quote
Old 05-09-2005, 05:55 PM   #20
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
DON't DO IT
there are plenty of places that sell radios with the knob and new inside's just look on the internet, please dont cut these trucks up
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 05-10-2005, 12:25 AM   #21
Bob Gervais
Truckless for the moment...
Bob Gervais's Avatar
I actually made an aluminum plate that mounts on top of the old opening, with the DIN size cut into it. The I scribed out the plastic bezel, and cut the metal dash. I used the two original screw holes, and drilled two new ones, and used longer screws to attach everything. I still need to paint the aluminum flat black, after drilling some holes to mount some toggle switches in it. Once it's done, I'll get some pics of it up. It'll look factory once painted, and there's no gaps or anything showing.
I used a jigsaw to cut the plastic, and the dash. I used a Prototrak CNC Bridgeport to cut the aluminum plate.
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now...
Bob Gervais is offline   Reply With Quote
Old 05-14-2005, 07:02 PM   #22
Ric83
Ric83's Avatar
I just bought one of those form the sound system place when I bought the rest of my system.
Ric
Here she is
Old 05-16-2005, 03:46 PM   #23
mhicks
mhicks's Avatar
They have a thing called a body saw. It has a blade like a jigsaw and it runs off of air. It looks like a small sawzall. It works great. They are a very handy tool. I picked mine up for about 25.00 at Harbor Freight.
mhicks is offline   Reply With Quote
Old 06-08-2005, 12:32 AM   #24
truckinbean
Has anyone seen this or used it before? http://www.scosche.com/scosche.aspx?...B&CategoryID=5
Not sure what's supposed to hold it in place since there aren't any holes for the screws. I was skimming the Summit catalog and found the listing for 73-87s so I looked it up. Only $10 from Summit, might be worth it.
Any thoughts?
Ben
'77 Blazer 2wd lowered 5/6
Goodwrench 350/700r4/3.73
Performer intake
Performer 1400 carb
Sanderson Headers/Dual 2 1/2" Flowmasters
truckinbean is offline   Reply With Quote
