Old 04-28-2005, 11:58 AM   #1
Ratrod60apache
Ratrod60apache's Avatar
Question Lowering with Torsion Bars ?????
I want to drop my 60 Apache 3" or so. It is equipped with torsion bar front suspension. Can I lower it with torsion adjustment alone, and is this a good way to lower it? Thanks!
Ratrod60apache is offline   Reply With Quote
Old 04-28-2005, 02:38 PM   #2
fishmunger
fishmunger's Avatar
yes you can and it is a good way to do it. if you check out chevytalk.com there is guy on there with a 62' that did it that way and could give you some more advice on how many turns = how many inches of drop
fishmunger is offline   Reply With Quote
Old 07-01-2005, 10:00 AM   #3
Ratrod60apache
Thanks!....anyone else with some advice??
'66 C10 Longbed Stepside, 350, 4-speed
Old 07-01-2005, 05:44 PM   #4
XXL
Seņor Member
XXL's Avatar
Torsion adjustment is the method in which spring rate is achieved. Simply cranking them down leads to a wimpy spring rate and thus a horrible ride and poor handling characteristics. I'm not intimately familiar with the Apache suspension so I don't have any specific suggestions... I would look at ways to raise the existing suspension as a whole, which will let you keep the spring rate because you're not changing the torsion bar adjustment.
XXL is offline   Reply With Quote
Old 07-02-2005, 12:12 AM   #5
newin72
I haven't done this on a chevy, but I raised my toyota using the torsion bars and it stiffened it BIG TIME.
I imagine trying to lower your truck 3 inches will take away ALL of your spring rate, and you will feel like your riding around on a trampoline...
newin72 is offline   Reply With Quote
Old 10-06-2005, 10:55 AM   #6
Ratrod60apache
Question
anyone else with some suggestions? Thanks!
Old 10-06-2005, 08:32 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've lowered about half the mini trucks in my area. I adjust the torsions bars down an equal amount on each side. It doesn't affect the ride that bad. A few inches is real tolerable.
ECE makes drop spindles for that truck if you want to go top notch.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
