07-31-2002, 09:54 AM | #1 |
CD Player/To cut or not to cut?
I really want to install a cd player in my 72 GMC, but I am looking for for some advice on wether I should do so, because I will have to cut out the area from which the radio sits to accomodate the cd player because it's bigger. I don't know if I should cut it out. I know another option would be a changer, but I don't want to do that. Also, what about speaker cut-outs in the door for speakers? Would these items hurt the value of my truck too much?
Aaron Ventura, Ca. 1972 GMC Super Custom SB350/TH400 |
07-31-2002, 10:20 AM | #2 |
I bought a unit from Dan Fink Metal Works. It's a box and faceplate that you can mount under the dash. It looks really trick and you don't have to cut the dash. The door holes can be easily repaired or covered at a later date. If you want more information on the unit I have I'd be glad to send it to you if you give me your e-mail address.
1977 Short Stepside, black, 350/350. Located in Albertville, Alabama. |
07-31-2002, 10:39 AM | #3 |
No, U Da Man!
This question always brings up a good debate, cut or not ?. If you want to keep this truck completely original? or Your going to do some non-original mods? Bottom line it's your truck. Do whatever you think best fits your needs. Cutting the dash makes the radio/CD player easily accesible, a remote controlled unit can work just as well without cutting.
(sold ole blue 1972) 1997 Dodge 1500 5.9L 1996 Saturn SL2 1.9L 2002 Mitsubishi Montero 3.0L 2005 Ford Escape 3.0L 1967 Olds Vista Cruiser 330-320HP |
07-31-2002, 11:09 AM | #4 |
Half a bubble off!
Stereos are easily replaced, dashes are not. Just say no to truck butchering!
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
07-31-2002, 11:26 AM | #5 |
14.1 @ 96MPH
It's your truck. Cut it.
I have yet to even think of regretting cutting my dash to fit my CD player.
Project1970 - LS1 Swap Complete! |
07-31-2002, 11:39 AM | #6 |
Debating this myself, and have a very basic (maybe slightly stupid) question.-
How do you cut it without messing up the paint on the dash? What do you use? Thanks |
07-31-2002, 11:46 AM | #7 |
Project1970 is 100% on the money - half of everyone here will say cut it and the other half will say never cut. The ultimate choice is yours - I would cut mine without a second thought because that is what I want. You need to do what you want to do, not what everyone else wants you to do.
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
07-31-2002, 12:52 PM | #8 |
cut it
cut it, you can always weld in a new plate or dash later. I wanna see what a nice cd player looks like anyways. Better yours than mine hehehe
I have a friend that put a dvd player in his car and it looks real 'trick'. If I could afford thet dvd player, I would put that unit in. Post some pics of your progress
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick" ~72 chev swb w/68 front clip "GM Millenium corvette yellow" I use and accept Paypal |
07-31-2002, 12:59 PM | #9 |
Dont do it
Dont Dont Dont,listen to Mikes67 that would be the way to go,please dont cut that dash!
Things happen for a reason! |
07-31-2002, 01:05 PM | #10 |
Got earplugs?
Hey Mike'67 I'd be interested in some info on that box for under the dash. Send it to wildcatfan95@hotmail.com Thanks
1968 GMC Original A/C, bucket seats, PS,PB 396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression Alltogether 411HP and 446ft/lbs Dana 60 w/ 3.54 gears Turbo 400 tranny Why would you have anything other than a big block? HAHA |
07-31-2002, 01:22 PM | #11 |
I am not cutting up my cab. I just don't see destroying a dash thats becoming ever more rare. Most people say you can just weld a new piece back in. Its never as easy as it sounds, plus, you'd have to take the center section of the dash apart, grind, body fill, and paint all inside a nice truck. Plus theres going to be a day when these trucks are not plentyful and finding good dashes is impossible. I'm going to have the only original one left on the planet!
BTW I'm putting a CD player mounted in the glovebox.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
07-31-2002, 01:41 PM | #12 |
I would not cut it 2 reasons:
Cant go back Have you EVER seen any type of newer install really look like it belonged in an older model??? No matter how much money you spend, they still look out of place!! IMO Put it under the seat or in the glove box.
Rod Childers '71 C10 Stepside |
07-31-2002, 02:21 PM | #13 |
Recovering Truck Driver
Here's what I did
It's a piece of 4" screen door trim alluminum channel.....very easy to work with and uses the screws which hold the heater controls with a couple self tapping sheet metal screws to eliminate vibration.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
07-31-2002, 02:31 PM | #14 |
Progress = 0%
Will you ever go back to an AM radio? Would you ever go back to front drum brakes? Would you ever go back to bias-ply tires?
Cut the sucker!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
07-31-2002, 02:39 PM | #15 |
geez, guess i ruined a cab, doors, short bleet bed and frame by making it look how i want. Cut the sucker, use a dremel tool with the cut off wheels and you can make nice clean cuts, you will go through several and make sure you wear glasses so when the break and bounce off your face youll still be able to see. I have a non cut dash if people want to start bidding on it, might be rare some day!!! im only kidding.
07-31-2002, 03:42 PM | #16 | |
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
07-31-2002, 03:54 PM | #17 |
Old Skool Club
lostwages got it right....if you want to cut the dash. I used the "sleeve" that serves as the mount for a JVC AM/FM/CD and scribed the appropriate cut marks. In essence, I had to cut out the section between the center and the knobs, then square-off the corners outboard of the knobs. When I was done, the sleeve fit snuggly, and the head unit looked nice. It was a mixed bag for me to cut it, but it looked nice when finished. My other truck is uncut, and will remain uncut. I plan to install a hidden unit and use a remote control. The radio in the dash will be for show, only. Besides, it doesn't work...unless I can find someone to fix it. I have an AM/FM (minus it's multiplexer) from a 67-68 Pontiac that I will use to fill in the blank.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
07-31-2002, 04:51 PM | #18 |
OzarkHillbilly in Atlanta
Go ahead and cut it if you want but please don't do it like the former owner of mine did.
Looking to find a way to fix this without cutting and welding if anybody has any ideas.
72 custom/10 LWB 68 Longhorn C20 Custom Camper (sold) |
07-31-2002, 04:55 PM | #19 |
its all about the +6 inches
Ouch...that looks bad.
I cut mine, and have not even looked back. I love my tunes, and as soon as i find doors worth cutting, they will get the axe too. I used a hack saw blade held with Vise-Grips...looks great. |
07-31-2002, 05:02 PM | #20 |
woodrow,
that's a major mutilation, looks like someone cut that hole with an axe.... I guess you could cut and screw a plate over the entire recessed opening and make a new hole for the stereo... If it were me, I'd find a thrashed cab with a good dash and cut the recessed radio portion out of it, then trim my hacked dash to accept the new piece and weld it in... time consuming but the best way to go if you have the know-how and the tools and patience...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project Last edited by bigvinnie; 07-31-2002 at 05:08 PM. |
07-31-2002, 05:06 PM | #21 |
Always make sure you know WTH your doing before doing any modifications!
woodrow59 - I would make an oversized, EVENLY CUT plate to cover that up, recut my hole for the radio and pop rivit the cormers
07-31-2002, 05:08 PM | #22 |
yes i did post something
hey i used vicegrips on a hack saw blade too and i hate to brag but mine looks just as good if not better than longhornmail, my point in all this is, if u do it right it looks just fine as long as u don't put like a sony xplode with freakin pictures and s h i t
p.s. when i first opened this i thought i was at an abortion board cut it, don't cut it, nothing looks as good as stock, mine looks clean and its not stock ha ha ha
you can want in one hand and s h i t in the other and see which fills first NO MATTER HOW BEAUTIFUL THE GIRL(S) IN MY AVATAR IS PLEASE READ MY POST |
07-31-2002, 05:22 PM | #23 |
Uh, why not just go with an underseat CD player, and use a custom autosound stereo system, and save hacking anything?
They look stock, but are new. I love mine, and it slid in with only a little swearing. No cut, it is irreversible. Someday the cd with go the way of the 8-track, and you will have cut for nothing. Dont do it!!!!!!
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
07-31-2002, 05:25 PM | #24 |
Cowboy Fan for Life!!!!!!
Cut it if you really want to but here are a few other options: My cd player is mounted in my console between the seats. (Don't know if you have buckets or bench, but this might be a good excuse to get the buckets and console.....) or mount it in the Glove Box and install a delete plate in the dash. Or maybe a trick overhead console from a late-model truck??? Whatever you do remember that it is your truck you have to build it the way you like it..................................JB
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
07-31-2002, 05:30 PM | #25 |
I'd cut mine in a heartbeat if i had a nice pioneer or something to put in it, my trucks cab is shot anyhow.
