Old 07-31-2002, 11:02 AM   #1
my67c20
Engine Code Identification
What kind of engine do i have? Codes offf the block are VO324TJU. I have used the search tool and was unable to come back with results. Also still looking for a 8 lug 3/4 ton axle with around 3.73 gearing compatible with a 67 C20. Thanks
my67c20 is offline   Reply With Quote
Old 07-31-2002, 11:25 AM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Where did you get that number? The engine block number should be on a flat pad( a extension to the block deck) at the back of the motor on the driver side. Once you get that number you can go to www.mortec.com and find the number. That site will tell you what you have.
Ben
67Fleetsidedream is offline   Reply With Quote
Old 07-31-2002, 11:38 AM   #3
Blazer1970
Blazer1970's Avatar
TJU is a '73 or '74 350 4bbl from a C-10 to 3500 van or bus. The '73 was rated @ 155 hp, '74 @ 160 hp.
Blazer1970 is offline   Reply With Quote
Old 07-31-2002, 12:50 PM   #4
my67c20
Id
Well i looked on the back of the block and went to mortec. Unfortunatly this is what i saw. Looks pretty vague. The first number i listed came from the front of the block passenger side. Which is real? And were did you get the info for the first set? Thanks
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
Old 07-31-2002, 01:11 PM   #5
67Fleetsidedream
Does the engine have a oil tube on the front of it? If so it is a 327. You can take a valve cover off and get the numbers and run them. Compare the 2 together to come up with a final assessment.
Ben
Old 07-31-2002, 01:24 PM   #6
my67c20
Oil tube is out the side.
Old 07-31-2002, 04:03 PM   #7
jhwkns
Registered Cruiser
jhwkns's Avatar
Thumbs up
010 block..... Thats a good one.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
