Old 05-02-2005, 06:45 PM   #1
Jason71k10
ready for reassembly
Jason71k10's Avatar
is this the HEI dist. that I need??
A buddy of mine gave me an HEI distributor for free, but i'm not sure if it's the one i need or not. It has three wires with a plug on the end. Is this the one that is used for the swap, or is this a computer controlled one?? thanks guys
Jason
stock 71 4x4
2003 Jeep Liberty, rocky mountain edition
I'm obsessed, and wouldn't have it any other way!
Jason71k10 is offline   Reply With Quote
Old 05-02-2005, 07:36 PM   #2
JimKshortstep4x4
Talking
Sounds like the right one. Does it have the vacuum advance on it?
Jim
Old 05-02-2005, 09:08 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If the plug is rectangular in shape, and plugs into the cap, and it is the only plug on it, then good score.
If it is an oval weather pack type plug, with the 3 wires in it...in addition to the plug going to the cap, then it is the early computer controlled one. There is a way to make the early computer ones work, but I don't remember how to do it.
Old 05-03-2005, 12:02 AM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Hey Andy, this site tell how to convert the ECE dizy to a non ECE...
http://www.73-87.com/7387garage/drivetrain/escrepl.htm
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 05-03-2005, 06:24 AM   #5
Jason71k10
Jason71k10's Avatar
Jim, it does have the vacuum advance on it. Andy, the plug is rectangular, and it's the only one on it.
Well it sounds like that's the one I need
What parts should I change on it before I install it? Is there a "rebuild" kit you can buy? Thanks guys
Jason
stock 71 4x4
Old 05-03-2005, 07:26 AM   #6
JimKshortstep4x4
Talking
What I normally do is check the end play on the shaft. If it is more than .010 to .012 I remove the gear and use washers of the right thickness to adjust the end play. Before reinstalling the gear the shaft is removed, cleaned and lubed with "Lubri-plate". (If the bushings or shaft is worn, they are replaced).
After reinstalling the shaft, I install new advance weights and springs. When it is back together I set the advance curve on my distributor machine. (I use the kit from Summit but the advance kits are available from other sources, also).
The vacuum advance is checked for operation and replaced if necessary.
Jim
