Old 05-03-2005, 01:58 PM   #1
PLavelle
PLavelle's Avatar
Cracked rim
To add to my long list of things I need to fix, I brought in a wheel that I thought just had a slow leak in the tire. They just called me up and told me that the rim was actually cracked and it was leaking out of there. Is it a bad idea to repair a rim in this situation? Should I just buy a new one?
1967 Chevy C10 Stepside - Vortech supercharged - Currently for sale
PLavelle is offline   Reply With Quote
Old 05-03-2005, 02:27 PM   #2
PLavelle
PLavelle's Avatar
Oops... meant to put this in the 67-72 message board.
Old 05-03-2005, 04:03 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Is that on your aluminum wheels? If so, it might be weldable, but will take a lot of work to polish it out.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-03-2005, 04:05 PM   #4
PLavelle
PLavelle's Avatar
Yes, it is unfortunately. They quoted me $175 to fix it.
Old 05-03-2005, 05:51 PM   #5
GMC AMI
GMC AMI's Avatar
Wink
4 Ralley wheels would cost less?
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 05-03-2005, 07:07 PM   #6
PLavelle
PLavelle's Avatar
Wrong thread I think, Mike.
Old 05-17-2005, 08:32 PM   #7
PLavelle
PLavelle's Avatar
I need to buy a new one. Anyone know who sells these six lug aluminum slotted rims? I bought them with the truck.
Old 05-18-2005, 05:13 PM   #8
PLavelle
PLavelle's Avatar
ttt anyone?
Old 05-18-2005, 07:36 PM   #9
Americanrider
Need to know the size, 16 or 15 X Width. I know of a tire shop close to me that has a few of those sitting outside, unknown if the are 5 or six luggers. Also posting your location in the top right would be a big help too.
Americanrider is offline   Reply With Quote
Old 05-18-2005, 08:01 PM   #10
Super Duck
Chevy Nuttttt
Super Duck's Avatar
how wide? I have 4 15x7s. if not cal Big Bubba's Tire in Spokane Wa.
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 05-18-2005, 10:10 PM   #11
Boog
laying low
Boog's Avatar
Plavelle. Hard to tell but those look like either ET slot wheels or Ansen Sprint wheels. There may be a name cast in the backside of the wheel along with the size. I had a set of ET IV alum slots on my first truck. A crack appeared in one of the rims after mounting them which leaked air. I put a tube in it and ran it for 8 or 9 years like that. No probs. If you really like the ones you have and want to stay with them then the 175 repair might not be bad as it's less than buying a whole new set. American Racing wheels is selling the Ansen Sprint slotted mags now. It is viewable at their website www.americanracing.com . Last page I think. I think there is another one or two selling that style slot mags but can't remember a name right now.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-19-2005, 03:40 AM   #12
69 Short Fleet
I would be pretty nervous driving on a cracked wheel (imho). Boog did ok as he mentioned... but... Those look like Ansen Sprint ll wheels from the pic, I believe they were on the market in the early 70's (great look wheels). I came across this website and found it interesting a few months ago http://www.roadsters.com/wheels/ Beutiful truck by the way. Doug
69 Short Fleet is offline   Reply With Quote
Old 07-14-2005, 09:34 PM   #13
PLavelle
PLavelle's Avatar
Ok, I know it has taken me a really long time, but I finally got the front wheel off to get all the numbers. I am converting the front to 5-lug disc brakes, so I need to find a pair to match the back until I can afford to buy what I really want for wheels.
Height = 15 in.
Total Width = 9.5 in.
Backspacing = 3 3/8 in.
Offset = -1.375 in.
Bolt circle = 5.5 in.
Seems like a pretty wide wheel for the front that I need to find to match. I am converting to the '71 setup for the disc brakes so I'm not sure if that changes anything.
Any help would certainly be appreciated.
Old 07-14-2005, 10:26 PM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I wouldn't go with the 71 brakes... IIRC, that was a one year set up and the parts are more expensive.
Old 07-15-2005, 05:41 AM   #15
I know you make it a point to know your stuff.So,where`d you get that?I`ve never run into that before.Aren`t the parts interchangeable?PLavelle,Do you already have the brake set-up?`Cause you can get 6-lug disc conversions.I always thought that was trick!
Old 07-15-2005, 06:59 AM   #16
PLavelle
PLavelle's Avatar
Yeah I bouight the setup from EarlyClassic.com to convert from 6-lug drum brakes to 5-lug power disc brakes. Haven't installed it yet though, as I need to purchase the wheels first.
Old 07-15-2005, 07:39 AM   #17
PLavelle
PLavelle's Avatar
I am planning on going 5-lug all around eventually, which is why I bought the front in 5-lug. I need a new rim on one side anyway, so I just decided to buy two new 5-lugs, and hopefully I can find a decent match to the slotted rims in the back.
Old 07-15-2005, 09:00 AM   #18
67ChevyRedneck
67ChevyRedneck's Avatar
I'm confused too longhorn.... my suspension came off of a '71 GMC coil spring truck. I didn't have any problems buying parts (I bought EVERYTHING brand new including the calipers and rotors) from either autozone or advanced.... (well, I did have to get the hoses from LMC) and the prices seemed reasonable to me. I don't think I spend more than $300 on the entire suspension and brake rebuild
Plavelle: I have the same problem you do. I have the exact same set of rims you do (the six lug, but mine aren't as shiney!) and I too have converted to a '71 5 lug disk front and still need to locate a good 5 lug rear. You may want to PM longhorn man and ask what the dilly is with 71's being "more expensive"
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-15-2005, 10:21 PM   #19
Longhorn Man
Hmmmm, this is gonna bug the crap outa me. I coulda sworn....
Oh well...sorry bout that. (and thanks for the correction)
Old 07-16-2005, 01:07 AM   #20
Blue_71
Bloo
Blue_71's Avatar
you can buy all the parts for 71 disc brake trucks just as easily as you can 72, but 72 will NOT bolt onto a 71 without changing stuff. the calipers fit in but then the hoses have to be changed to. so they are interchangable, but with extra parts added in... 72 calipers are about $12 each and 71 about $22 each. the 71 hoses are also more expensive... ive ran into this on both of my 71s when i tried to buy the cheaper 72 calipers
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-17-2005, 11:48 AM   #21
Longhorn Man
Cool. So I was right, just the price differance isn't all that much.
