Old 05-17-2005, 10:18 PM   #1
cliffsta
Stepsides RULE
cliffsta's Avatar
Alternator function question
OK please enlighten me.
Doesn't an alternator provide constant juice to the electrical system? My dad said he thought it just gave juice to the battery or whatnot when the volts dropped off, and otherwise the volts would go down until the draw was great enough to warrant its juice.
The reason i ask is because sometimes, my volts start dropping off, fall below normal, even dip below 13, and i rev it up and it has no effect on the volts, then all of a sudden the volts start going back up. is that a bad alternator, or is that how it functions? Bad connection maybe? where would that be if that's the case?
thaniks,
cliff
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 05-17-2005, 10:37 PM   #2
Russell
Professional Grade
Russell's Avatar
Sounds like a bad connection to me.
An alternator will provide 14.6 volts by itself, you can take the battery right out of the truck, and it will continue to run off the alternator. My truck would occasionally do that as well, and it'd always be an issue with the the connection on the starter, came loose all the time.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-17-2005, 10:43 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
The alternator is your source of power to the engine, truck and the battery. It will carry the vehicle without the battery. If you are seeing the voltage drop and then jump up all of a sudden, then your voltage regulator is not working well. If you have a truck that has the alternator with the internal regulator, then the diodes are not working well and it needs to be replaced. The older trucks had an external regulator and it could be sticking (mechanical design). The voltage should be read at the battery by a volt meter of 13.5 volts to 15 volts depending on the load on the truck. A voltage of 14.5 is desired to keep all working and the battery charged. You could also have a bad cell on your battery that may be causing the alternator/regulator to be confused. I recommend that you have the voltage output checked and then have the battery LOAD tested to see if it is good.
Old 05-18-2005, 12:59 AM   #4
hotrodhomi
hotrodhomi's Avatar
I wouldn't count out the less than precision instrument in your dash. They’re not the best either.
hotrodhomi is offline   Reply With Quote
Old 05-18-2005, 07:48 AM   #5
piecesparts
A hand held volt meter is a good thing.
Old 05-18-2005, 05:46 PM   #6
cliffsta
Stepsides RULE
cliffsta's Avatar
Nah, the gauge is accurate. I shall check all the connections, that's kinda what i thought it would be, but i'm just an idiot.
