Old 05-17-2005, 10:30 PM   #1
CAJ68
gas gauge
what is typical reason for gas gauge to not work? shows way past full all the time.
CAJ68 is offline   Reply With Quote
Old 05-17-2005, 10:34 PM   #2
jamal
jamal's Avatar
I have same problem, would like to know this as well
jamal is offline   Reply With Quote
Old 05-17-2005, 10:56 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the brown wire being grounded out.
The wire that goes from the tank to the fuse panel is probably shorted to ground. Most likely, it'll be under the chrome strip under the drivers side door at the carpet edge.
Old 05-18-2005, 02:17 AM   #4
A.P.
Black 72 Chevy
A.P.'s Avatar
I just went to check on my truck. I disconnected the brown wire that is connected on the tank, and the needle on the gauge went way past full. I shorted the wire to ground and it went to empty. So if your needle is going past full, you a break in the wire.
A.P. is offline   Reply With Quote
Old 05-18-2005, 04:55 AM   #5
Longhorn Man
DOH
dislexia is a hctib
Old 05-18-2005, 10:16 AM   #6
CAJ68
thanks i'll check it out.
Old 05-18-2005, 10:43 AM   #7
jfrank133
AUSTIN TX
jfrank133's Avatar
I have Dual tanks and it dont matter which tank im using, my needle never moves from 1/4 tank. can this also be the brown wire.
jfrank133 is offline   Reply With Quote
Old 05-18-2005, 12:10 PM   #8
avejoe
Custer had a plan too.
avejoe's Avatar
Don't mess with a good thing. If your gas gauge reads full all the time, go with it.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 05-18-2005, 03:29 PM   #9
kxmotox247
kxmotox247's Avatar
I had a bad connection or something like that at the fuse block on my 67. I never did figure out exactly what I did to get it to work but some wiggling around the fuse panel resulting in a working gas gauge for me.
kxmotox247 is offline   Reply With Quote
Old 05-18-2005, 06:01 PM   #10
CAJ68
with the brown wire plugged in fuse box,i can take the other end and hold to a ground, the gauge goes to empty. that tells me there is no break in wire.if the wire is not touching anything it shows past full. if it is conected to sendig unit there is no change, it shows past full. does this mean the sending unit is not giving signal? also i know i have about 7 gallons,how many does it hold?
Old 05-18-2005, 08:42 PM   #11
Longhorn Man
some tanks hold 17, most are more like 22 gallons. (pick ups...no idea on the blazer/burb)
Your testing is correct, as is your conclusion. The guage is working fine, the wire is good, and the sending unit it not giving a reading. You may pull it out and see a broken wire, but plan on replacing it though.
Old 05-18-2005, 09:09 PM   #12
86swb
Born a Chevy Man
86swb's Avatar
Maby it is just me, but I do not think I would go with this plan.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
