05-18-2005, 07:32 PM | #1 |
Car O'Holic
Body Mounts
How do the body mounts on the cab put together? I have the round rubber pieces and then these cone looking ones and the bolts and washers but how is it all susposed to piece together?
05-18-2005, 07:56 PM | #2 |
I am not sure how your kit is set up, but the round doughnut sets onto the frame mount with the protrusion down through the hole. The large washer goes on top of the doughnut. There should be a spacer (pipe) that fits into the doughnut and the tapered rubber part fits over the spacer with the small end down. When installed the two pieces of rubber sandwiches the frame mount so the large doughnut is on top and the tapered rubber is on the bottom.
On the rear mounts the bolt screws into the body from below through the setup with the smaller washer on the bolt. On the front mounts the bolts go through the floor and through the mounts and there should be a nut for the bottom end along with a washer. Jim |
05-18-2005, 08:23 PM | #3 | |
Car O'Holic
05-20-2005, 01:09 AM | #4 |
What's that funky smell?
Got it mounted yet? Did you end up switching to the high hump?
Mike S 68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck 3 on the tree, 307, No power brakes or steering Factory Options - HD rear spring and Ammeter/Oil Gauges My truck blog My Car Domain page |
05-20-2005, 10:54 AM | #5 |
No,I DON'T have Tourett's
doughnuts.........sandwiches.........I'm getting hungry
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
05-20-2005, 05:51 PM | #6 | |
Car O'Holic
