Old 05-19-2005, 11:56 PM   #1
c10chevy69
c10chevy69's Avatar
starter problem
My starter seems to have a hard time starting without grinding almost everytime. I have pulled it out and looked at the teeth, put it back with both shims (1/16 &1/32), both shims by themselves, and no shims. Still the same thing. Any ideas? Also can anybody tell me if my original tranny or not. The starter that fits this truck according to AZ is a 72. It is the starter that the bolts are offset from each other and bolt straight up into the trans.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug
c10chevy69 is offline   Reply With Quote
Old 05-20-2005, 12:02 AM   #2
ZOOMY
starter
If all else fails, try new starter bolts. If they get bent, the starter will wobble when you're tightening it. This will cause misalignment. NAPA has them on the quik-fix rack or whatever it's called.
ZOOMY is offline   Reply With Quote
Old 05-20-2005, 01:16 AM   #3
Goose
Goose
Goose's Avatar
I used to have this very same problem. Once I replaced the original starter that went with the engine - in my case it was a 350 block, I could never get satisfactory starter life and experienced the grinding and replaced several starters and a flywheel or two. It just seemed I couldn't re-establish the correct relationship between the flywheel and the bendix using replacement starters except for fairly short times. Finally, instead of going to my neighborhood parts store for another starter and different shims I took my problem to a speciality starter/alternator shop. They recognized my problem and said I needed the heavy duty "Canadian version" of the starter tail housing. They rebuilt my starter using this version and I haven't had a problem. Now I really don't know if there is a "heavy duty Canadian version" or not, but what ever they used seemed to work. Might be worth checking into. There's nothing nastier sounding than a grinding/spin out starter - unless it's a header leak!
'72 GMC short-step 350/350
Goose is offline   Reply With Quote
Old 05-20-2005, 10:42 AM   #4
krue
Designated A-hole!
krue's Avatar
I experienced a similar problem and finally wound up with a nosecone that uses bolts straight across from each other instead of on a diagonal.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-20-2005, 11:34 AM   #5
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
What a trip! I've only saw the one on the left. Allways learnin somthing new...
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 05-20-2005, 09:46 PM   #6
kaycee
kaycee's Avatar
Exclamation
Don't you have to run a different flywheel for the straight across bolt pattern?Seems like I was going to use that setup but my flywheel was to big.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 05-20-2005, 11:20 PM   #7
krue
Designated A-hole!
krue's Avatar
No I only changed the nose cone. Works great.
www.daveramsey.com
Old 05-21-2005, 09:23 AM   #8
c10chevy69
c10chevy69's Avatar
Where can you get a new nose cone from?
Old 05-21-2005, 09:33 AM   #9
kaycee
kaycee's Avatar
Unhappy
OK talk about bad luck I went out and started the 69 and the starter is growling bad.I just put a new reman. on it and have not put 50 miles on it since and maybe have started it about dozen times,I'm not even running headers
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 05-21-2005, 11:28 AM   #10
krue
Designated A-hole!
krue's Avatar
To get mine I went to a local auto-electric shop. They had it in stock. When I told them what was happening that's what they told me would fix it. So far (8 or so months later) so good.
www.daveramsey.com
Old 05-21-2005, 01:25 PM   #11
Pilgrim
I had the same problem and got it fixed as krue did.
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 05-22-2005, 12:21 AM   #12
c10chevy69
c10chevy69's Avatar
I followed some advice from a friend and got it working. I went to Autozone and bought a starter with the inline pattern for a 72 camaro. I tried to install it and it would not fit of course. I pulled it apart per the advice I was given and swapped the nose cone. Put it back in after straightening out the cover that bolts to the trans (can't remember what it's called) with no shims and it fired up with no grinding. Sounded awesome. Keeping my fingers crossed that this is the fix. Thanks for all the advice everyone.
Old 05-22-2005, 12:27 AM   #13
krue
Designated A-hole!
krue's Avatar
Glad to hear it worked.
www.daveramsey.com
