Old 05-21-2005, 10:00 AM   #1
TruckinDaddy
What's that funky smell?
TruckinDaddy's Avatar
2BBL Carb Install?
I installed a Rochester 2BBL carb - my first attempt at a rebuild. The rebuild kit came with all the gaskets, including the carb to intake gasket. After install, it leaks at the carb to intake gasket.
I used the paper gaskets that came with the rebuild kit. Should I have used a gasket sealer, too? Or is there a better type of gasket?
This is my first effort at a truck and I appreciate all of the help I have gotten from this board.
Mike S
68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck
3 on the tree, 307, No power brakes or steering
Factory Options - HD rear spring and Ammeter/Oil Gauges
My truck blog
My Car Domain page
TruckinDaddy is offline   Reply With Quote
Old 05-21-2005, 10:13 AM   #2
Sweet72
Sweet72's Avatar
Vacuum leak or fuel leak? The paper gaskets should do the trick, no sealer is required. Did you make sure that your carb and intake surfaces are clean and flat? Check them with a straight edge. Tighten the bolts down a little at a time to and evenly all the way around, and be careful not to overtighten or you'll warp the flanges on the carb. You can clean up any minor irregularities on the surfaces with a flat mill file.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 05-21-2005, 10:54 AM   #3
jhow66
jhow66's Avatar
Your carb is flooding. Recheck your float level and needle and seat. There probably is something (speck of dirt) under the needle.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-21-2005, 12:13 PM   #4
TruckinDaddy
It is a fuel leak. Thanks for the advice. I'll check on the surfaces and the float and needle today.
Mike S
My truck blog
My Car Domain page
Old 05-21-2005, 01:22 PM   #5
Pilgrim
Sometimes a pice of crud in the carb can be cleared by removing the air cleaner, with engine running, open accelerator, then cover carb with a big folded towel. This causes gas to really flow rapidly into carb usually cleaning out any dirt particles left behind. Might have to do this a few times.
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
