05-24-2005, 07:13 PM | #1 |
Holley electric choke question
I just picked up a used Holley 600 with electric choke. Between the choke and carb body there is a red plastic cam thingy mounted on the butterfly shaft. It doesn't appear to be connected to anything but will hold the throttle partially open when lifted. Works like a cam on a mechanical choke. I don't see anywhere that it should be connected to the choke . Am I missing a spring or something?
05-24-2005, 07:22 PM | #2 |
thats a fast idle cam and there should be a adjusting screw on the bottom and is kinda hard to see and get to
Guy |
05-24-2005, 07:41 PM | #3 |
I can see the screw and some notches on the cam but what controls the cam's movement? It just flops around.
Mark |
05-24-2005, 08:34 PM | #4 |
It's connected to the windings in the choke bell. It will move freely when the choke is off.
05-24-2005, 08:51 PM | #5 |
Thanks... I guess I got a bad choke. It just moves all the time. Took the choke off and the idle cam just turns on the shaft.
05-24-2005, 09:39 PM | #6 |
when the choke is cold theres a lever off the back of the choke housing that controls the fast idle cam , when choke is hot the cam will flop around - what keeps it from going to a fast idle when the choke is hot is the weight of the cam itself . hope this helps
05-24-2005, 10:09 PM | #7 |
I think I see how it is supposed to work but what moves the cam so the screw will touch the cam step when cold? Maybe I'm missing a lever. I took it off for pics. Does everything look right? Thanks
