![]() Join Date: Mar 2001
I am going to replace the front springs in
my C-10 with a 350 engine. Looking at GMCPauls website, he has listed a standard spring and a variable rate one, which ones are the best to use. This truck will only be used on the street (as a daily driver) and will probably never really haul much, maybe tow a trailer at most. Any input? Thoughts on what is the best springs to use. I may also end up replacing the rears as well (they are coils too) THANKS! ------------------ 71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73 See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
I asked the same questions. I just replaced my front and rears from GMCPaul. I went with stock height variable rate front and 4 inch rear. I havent driven mine much. I droped the front with spindles. I have just (Friday night) put new shocks on I have not got the front end realigned so I am going to try to do that this week. I went over a dip with a buddy in the truck and the tire bottomed out on the inner finder just barely barely kissed one of the bolts this was before I put on the shocks. I was told the shocks for the lowered truck are stiffer and that was my problem. The little I have driven it it corners GREAT. the ride is good too. My old springs were worn and completly shot. To answer your question I dont know? My variable rate seem good but it seems to sit lower in the front than I would have expected.
I will let you khow more as I drive it more. Hopefully this week. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
![]() Join Date: Feb 2001
I also purchased a spring, shock, drop spindle kit from GMCPaul...I bought the variable springs...Rides great & much improved handling w/o any problems.
70cst with a 402BB
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
