05-27-2005, 10:04 AM | #1 |
hot underdash wires
With the fan running, I noticed a couple of the wires leading to the switch are hot to the touch. You can bear your fingers on them, so it's not like they're melting or nothing, just hot enough to make me wonder.
Is this normal? I'm an electrical dufus, in case you haven't guessed. |
05-27-2005, 10:14 AM | #2 |
No,I DON'T have Tourett's
might be a leak in one of your duct hose.........blowing hot air on the wires.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
05-27-2005, 10:15 AM | #3 |
Lovin' Life in Miss.!
Warm wires indicate high resistance. Clean up all of the surfaces on your ground for the fan motor. It is the bonding wire that leads from the case of the fan to the firewall. There is a resistor mounted in the heater box. I do not know what the ohm readings should be for it maybe someone else will...
The truck... you hear that? No really, you did hear that?!!! |
05-27-2005, 10:22 AM | #4 |
Also wires will heat up if the connectors are loose-make sure all slip on plugs are tight.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
05-27-2005, 10:46 AM | #5 |
Born a Chevy Man
I worry about stuff like that. This is why I keep a fire extingisher in my trucks. Just in case.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) CHEVY, American made w/pride! If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
05-27-2005, 10:50 AM | #6 | |
05-27-2005, 10:52 AM | #7 |
Born a Chevy Man
Are you sure you have the right fuse for those wires?
05-27-2005, 10:53 AM | #8 |
Born a Chevy Man
The right fuse should blow if wires gets too hot.
05-27-2005, 11:01 AM | #9 | |
HOWEVER...you know what they say about assumptions. |
05-27-2005, 11:04 AM | #10 |
I'd check it out soon. My fan did not work when I first got the truck. When I pulled the fan switch connector it had 1 pin half melted off! Never figured out the cause, I was replacing the whole harness anyway.
05-27-2005, 11:08 AM | #11 |
Born a Chevy Man
You sure do not want to have a fire and nothing to put it out with. You could just say to your nice truck.
05-27-2005, 11:17 AM | #12 |
Half a bubble off!
Not sure how accurate this is, but I was told once by a mechanic that the wires to the fan were notorious for over heating, and he said it was (in his opinion) because GM used to light of a guage wire for the application. When I had my dash all apart, I found mine were on the verge of burning, so I was concerned myself. He came over and replaced them with the appropriate sized wires, and I have never had any problems since. Like I said, it might have been just his opinion, but what he did seems to have been an improvement, and I feel a little more at ease when using the fan.
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
05-27-2005, 11:25 AM | #13 |
Someone, maybe Putter, outlined going to a relay set-up for all of the fan speeds.
