Old 05-28-2005, 03:43 AM   #1
Russell
Professional Grade
Russell's Avatar
Progress
Getting closer!
However, I am screwed as far as the serpentine setup goes. My TPI intake will not work with it at all.
Not only will the base not fit, but the throttle body will hit the tensioner smack dab in the center. So I guess this setup is for sale, and it is time to find a setup off a 4.3 or a 3rd gen Camaro...
I'll post more pictures when I've got things figured out.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-29-2005, 01:45 AM   #2
Russell
Professional Grade
Russell's Avatar
Alright, now I've got something to show you guys
Tell me what ya think!
Old 05-29-2005, 01:52 AM   #3
longhorn71
longhorn71's Avatar
lookin good Russ
longhorn71 is offline   Reply With Quote
Old 05-29-2005, 02:06 AM   #4
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Now that is professional grade!
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 05-29-2005, 02:07 AM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Ya, progress is looking very good. What all else do you need to get finished up and squared away?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-29-2005, 02:12 AM   #6
Russell
Professional Grade
Russell's Avatar
As far as rust repair goes, I gotta patch the pass side floor pan, and coat it. Gotta sand down and self etch prime the roof / some other surface rusted areas, then shoot the cab with epoxy primer, then she'll be good to go back on. Frame needs the rear to be sand blasted, or wirebrushed. I haven't figured that out yet, its tough getting the angle grinder between the frame rails.
As far as parts go, I need a two peice aluminum serpentine belt setup with the power steering pump, AC compressor and tensioner. I need to get my divorced t-case here, get driveshafts made (I am gonna run it with a 2wd shaft until I can afford the driveshafts, at 200 a pop, I need to spread the cost out a bit) and I need a 2wd tranny crossmember with the high arches on either side to clear the exhaust. Any pre 79 truck should have one. Also need brake lines from the splice under the cab to the rear end and the hard lines on the rear end. Also need a driver's side fender
Things to do yet include installing and plumbing the EFI burb tank, installing the TPI electrical harness, change the rear drums out to the HD drums from my old 14 bolt and a couple other small things
I can see myself with it running by the end of the week if all goes as I want it to
Old 05-29-2005, 05:22 AM   #7
bigarmzz
bigarmzz's Avatar
man, that looks really sweeeeet!
what did you paint your frame with?...that dont look like a spray can job...
good job russell!
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 05-29-2005, 10:13 AM   #8
bigblock73
yeller
bigblock73's Avatar
Russell, your progress looks super....good job man!!
Keep us updated with your progress, can't wait to see it all come together.
bigblock73 is offline   Reply With Quote
Old 05-29-2005, 12:45 PM   #9
Russell
Professional Grade
Russell's Avatar
I coated the frame with a product called Zero Rust. My only complaint is that the stuff dries too quick in the sun, and doesn't smooth out :P
I'll probally give the axle and such another coat just to try and smooth it all out a bit
I am VERY impressed with it's durability though! I accidentally bumped the top of the frame with the bobcat bucket, and it didn't even scratch it! Its a sort of a softer coating that bends and stuff to absorb impacts. I am gonna buy another gallon so I can do the under side of my bed, fenders etc. The half gallon I've used has coated most of the bottom of my cab, and most of the front suspension I can definitely finish the cab and the frame with the single gallon. Box and stuff will need another gallon :P
Old 06-01-2005, 11:54 PM   #10
Russell
Professional Grade
Russell's Avatar
Got my cab on tonight, dang its tall
4 and a half coke cans of clearance
Old 06-02-2005, 12:00 AM   #11
82c10
needin' money
if you don't mind me askin, where did you get the zero rust stuff, and how much $$$ did it cost?
82c10 is offline   Reply With Quote
Old 06-02-2005, 12:22 AM   #12
Russell
Professional Grade
Russell's Avatar
I bought it off a forum member for about 45 bucks shipped, if I recall right...
You can find a distributer at www.zerorust.com. Just gotta email them, and they'll let you know where to find it
