Old 05-28-2005, 02:47 AM   #1
xtinc
4sp to TH350 procedure
I have a '67 C10 Fleetside LWB. I'm getting ready to replace my 4sp manual transmission with a TH350. I'm looking for someone who has accomplished this task that could give me a little insight on what's involved. Couple questions I have are:
1. Will I need to cut a hole in the floor of the cab to reposition the shifter or can I use the existing hole? I have not decided on type of shifter I will use yet, maybe a Lokar. Any suggestions.
2. Will my existing drive shaft work?
Any other tips will be appreciated. What happen to the search function anyway?
Tom
xtinc is offline   Reply With Quote
Old 05-28-2005, 04:48 AM   #2
krue
Designated A-hole!
krue's Avatar
Go to the FAQ index here and look for a thread on it. http://67-72chevytrucks.com/vboard/s....php3?t=157669
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-28-2005, 04:43 PM   #3
xtinc
Couldn't find any info on the 4sp SM420 to Th350 swap in the FAQ index. Anyone else done this swap?
Old 05-28-2005, 08:06 PM   #4
72BLAZERDUDE
72BLAZERDUDE's Avatar
Not to hard a swap. I did it a number of years ago so I will try to remember as much as possible. Yes you will have to get a new drive shaft. Four speed is alot shorter transmission so you will need a shorter driveline for the T350. If you have a one piece driveshaft you might should be able to get it shortened should only need to get a new front yoke welded on. You will probably want to get a low transmission hump from an auto truck so it probably wont have a hole in it.. If you want to use a shifter like a Lokar you will have to put a new hole in the floor. If you use a cable type shifter it is a very small hole for the cable to run through. You will also need a different crossmember for the rear trany mount but the holes should already be there. These are just a few of the basics that I can remember. Ask away as I am sure there alot of things I haven't thought of.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
