Old 05-30-2005, 01:11 PM   #1
Oborny71
Oborny71's Avatar
minimum ground clearance on the street?
what is the minimum ground clearance required for the street? the 3 1/2" exhaust i'm putting on my lowered 67 is is only gonna clear the ground by the 3" . besides speed bumps, is this gonna be ok?
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
Old 05-30-2005, 01:36 PM   #2
Oborny71
Oborny71's Avatar
pics to follow
Old 05-30-2005, 01:49 PM   #3
fastbagged68
fastbagged68's Avatar
You could do what I did... box the frame and cut a whole through the frame and run your exhaust through the frame and keep it above your frame rails... or can C-notch your frame to clear exhaust...
fastbagged68 is offline   Reply With Quote
Old 05-30-2005, 02:27 PM   #4
SCOTI
SCOTI's Avatar
You'll clear alot of road stuff but eventually you'll hit something.
Why not try & tuck that up as much as possible within the frame rails? In those pics it looks like the entire system is below the bottom of the rail. I understand it's 3.5" dia tubing, but mine has 3" & you can't see any of it & it dumps @ the rear-end housing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-30-2005, 05:12 PM   #5
AirMale
AirMale's Avatar
what headers are you running?
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 05-30-2005, 08:03 PM   #6
Oborny71
Oborny71's Avatar
the headers are hooker super comps, 2" primaries, 3 1/2" collectors. the problem is more in the headers i guess. they hang below the tranny crossmember, so in order to run the rest of the exhaust, it has to be below it too.
Old 05-30-2005, 08:22 PM   #7
71Dragtruck
71Dragtruck's Avatar
I put a tubular cross member on my tranny, it has a u shaped bend under the tranny. I then used mandrel s bends to take my exhaust up into the frame rails.
71Dragtruck is offline   Reply With Quote
Old 05-30-2005, 08:43 PM   #8
AirMale
AirMale's Avatar
Most guys have more luck with the Hooker competition headers #2455 instaed of the "super-comps". They tuck up between the frame rails nice.
86 SWB 9.0 LITER
Old 05-30-2005, 10:20 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
You may as well go ahead and pull that off and lay it in the back of your truck. It's going to end up there anyway after you drag it off. Unless your truck is bagged, and I know it's not, that never going to last....
Old 05-30-2005, 10:38 PM   #10
Elsie72
Chinook Arch
Elsie72's Avatar
Damn! That's exactly why I'm considering mid-length or shorty headers. I know it might not be the best for outright performance, but I would be nervous every time I went over a bump in the road.
Right now I've got 2 1/2" pipes, tucked above the bottom of the frame rails, over the transmission cross-member, and I've yet to drag anything.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
Old 05-31-2005, 08:36 AM   #11
XXL
Seņor Member
XXL's Avatar
You're making those of us with exceptionally low trucks wince. As N2TRUX has already indicated, those are going to fall into the "I used to have these on my truc" category if you actually drive anywhere. You'll be extra careful, but that one time you're forced into the lane with the big bump and the 18-wheeler is riding your bumper, you're going to shred them.
XXL is offline   Reply With Quote
Old 05-31-2005, 05:33 PM   #12
72MARIO
72MARIO's Avatar
You need to find another set of headders. And tuck it up in the frame.
That will never last.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-03-2005, 03:57 PM   #13
FirstGen
Just Don't Stop!
FirstGen's Avatar
I went to midlengths after the same problems. I lost no power actually with the ported MACs I now have...
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 06-03-2005, 04:46 PM   #14
speedracer
Blank
speedracer's Avatar
with my 4-6 drop I caught a rock on a dirt road going about 15mph It tore the flange right off the header. I'm running shorty hedmen elites now. 4" more ground clearance. Worst part of learning this the hard way was the 3" stainless and flowmasters I had to throw away because of speedbumps and dips in the highway; scraps, rips, and crushed pipes everwhere.
speedracer is offline   Reply With Quote
Old 06-04-2005, 01:39 AM   #15
72MARIO
72MARIO's Avatar
http://www.nwautofab.com/store/custo...&cat=11&page=1
Try these motor mounts and a set of camaro shortys. I would get the hedders first. If they hit use these mounts. I have them on my small block and they clear my headman shortys.Small block thought..
2005 TAHOE DD
