08-05-2002, 04:26 PM | #1 |
I Love This Stuff!
Help, How do I remove my guages?
I'm in the process of tearing apart my truck and I am stuck trying to tke the guages out. I removed all of the screws around the perimeter on the guage panel. How do I get the choke, wiper, and light knobs off? what else is holding the guages onto the dash?
Thank You Guys!! JHickson6
My Rides 1967 C10 In Pieces for now 1985 Ford B700 SourPuss Bus - BIG BLUE 2003 Silverado CITY WORKER YELLOW!! |
08-05-2002, 04:29 PM | #2 |
You'll need to take a small screw driver or pick and pull back on the tab (just at the base of the knob's) then remove the 2 retaining nuts for the choke/headlight switch.
If you have a small mirror you can pull the headlight switch on and look behind the knob, you will see a tab sticking out around the base of the knob. |
08-05-2002, 05:54 PM | #3 |
The wiper knob has a set screw. Unscrew it with a small screwdriver, loosen it so you can pull the knob off. For the lights, pull it out to parklights, reach up behind, push the tab down and pull out. I had the same problem a few weeks ago.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
08-05-2002, 06:24 PM | #4 |
I Love This Stuff!
thanks guys i got them and the most of my dash!!!
I took two bolts out of both sides of my dash and it still doesn't come out, it it welded in? JHickson6
08-05-2002, 06:26 PM | #5 |
GAUGES
AFTER YOU GET THE NOBS YOU WILLNEED TO TAKE THE OIL PRESSURE LINE OFF AND THE SPEED OMETER LINE THEN THE HOLE THING SOULD COME OFF
08-05-2002, 06:30 PM | #6 |
OH! your taking the whole dash out?? I believe these are pinch welded to the cab and make up part of the windshield sealing surface.
08-05-2002, 07:06 PM | #7 |
OzarkHillbilly in Atlanta
Yeap .... if you're talkin whole dash , that's a new ballgame.
Good Luck !!!!
72 custom/10 LWB 68 Longhorn C20 Custom Camper (sold) |
08-05-2002, 09:28 PM | #8 |
I Love This Stuff!
Thanks again guys, it's all done!!
JHickson6
