Old 06-01-2005, 04:14 PM   #1
Nima
Blue 67
Shocks and springs
Hi everybody:
If I want to soften my c20 ride a little, what kind of shocks and spring do you suggest? I don't want to convert to C10 totally, I just want a better ride. I have shock and coil spring on the front, shock, spring and 1/2 leaf on the back. If you can give me some part numbers, that would be great. By the way, I like to keep the current hight of my truck the same. It is not lifted or anything, I think it is just factory with bigger tires. Thanks
Nima is offline   Reply With Quote
Old 06-01-2005, 11:57 PM   #2
Nima
Blue 67
huummm!!
Old 06-02-2005, 04:07 PM   #3
Nima
Blue 67
Wow!, Nobody?!
Old 06-03-2005, 12:00 AM   #4
Nima
Blue 67
Am I on my own on this one? Or maybe I offended some one here!
Old 06-03-2005, 12:54 AM   #5
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Its a 3/4 ton. Its going to ride rough. Put some good smooth riding shocks on it from the local parts store and it should do fine. It will always ride rough, it a big truck.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 06-03-2005, 10:49 AM   #6
Nima
Blue 67
Thanks for writting back. Well, I know it is C20 and has though ride but I thought since I am going to replace the whole front end and switch to disc brake, at the same time replace the shock/spring with something which could give me better ride. Thanks anyway.
Old 06-03-2005, 08:53 PM   #7
Don Meyer
Use a latter model 1/2 ton front end complete w/disc brakes.
Don Meyer is offline   Reply With Quote
Old 06-03-2005, 09:43 PM   #8
Ogier
Chopper/Painter
Ogier's Avatar
Mine is a 69 and it rides really nice.
CHeck your air pressure in the tires. I would be willing to bet that you have it maxed out.
Drop about 10 pounds from the max pressure and it will do wonders for the ride. Perhaps sometime I should do a tech article on how to properly inflate tires.
With regards,
Ogier
1969 Chevrolet C20 - Resto-Custom started!!!
Ogier is offline   Reply With Quote
Old 06-03-2005, 11:11 PM   #9
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
If you're going to replace the shocks, don't use the gas charged shocks. They ride rough as hell. Just use stock replacements and it should ride fine. Does your truck have rear coil springs? Mine does and it rides awesome, even on the rough county roads.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 06-03-2005, 11:49 PM   #10
Green Machine
Green Machine's Avatar
I believe that front and rear coil springs interchange between 1/2 and 3/4. Might try some 1/2 ton springs front and rear. If your're banging into the rear helper springs, try removing them if you don't load it heavy often.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-04-2005, 12:56 AM   #11
Nima
Blue 67
Yes, I do have coil spring on the rear and gas shocks all around. I also have helper leafs on the back.
About my tire pressure, they are at least 10 psi lower that highest recommendation but still ride rough.
Old 06-04-2005, 07:50 AM   #12
Huck
Huck's Avatar
There are some basic principals at work here. Check the tires --what size, how many belts on the sidewall, etc. Some brands are really stiff like Michelin. If they are old, they also get real stiff (like people). If truly truck tires, they are heavy and stiff so no matter what springs, shocks you get, it will let you know when you hit mouse poo. Also if they are oversize they will ride harder then stock size. My Blazer/trucks call for 235x75R15 but I run 33" biggies and the ride is much harder but it does look cool!!
I run about 32lbs of pressure on tires unless I am hauling. That works fine. A 3/4 ton has much heavier rear axel assembly so you are dealing with that when it comes to springs and shocks. You can put in 1/2 ton coils out back which will help. Another solution is to put about 500lbs of brick in the bed--amazing what a little weight will do to smooth out a ride!! hehehehe
Huck is offline   Reply With Quote
