Old 06-01-2005, 06:12 PM   #1
ZmOz
Truck won't turn over in park
'79 C20, 454/TH400...
Got in the truck today to park it somewhere else, wouldn't start in park. Starter didn't budge and no clicking. Put it in neutral and it started. I'm guessing there's a bad nuetral start switch somewhere. Where is this switch and what do I need to do to fix it?
ZmOz is offline   Reply With Quote
Old 06-01-2005, 06:26 PM   #2
BALDMIKE
Enormous Member
BALDMIKE's Avatar
Did you check your battery terminals and also check your positive wire that connects to the starter........
"79" Chevy Stepside 350/350
Check my Blog @ www.BaldMikesWorld.blogspot.com
BALDMIKE is offline   Reply With Quote
Old 06-01-2005, 06:31 PM   #3
ZmOz
No, but like I said, it started in neutral, so the connections must be fine.
Old 06-01-2005, 06:50 PM   #4
BALDMIKE
Enormous Member
BALDMIKE's Avatar
Never assume when it comes to something as simple as connections.
It's easy enuff to check both those fixes 1st........
Old 06-01-2005, 07:12 PM   #5
Russell
Professional Grade
Russell's Avatar
Yeah, there is a switch at the base of the column that probally went bad on you.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-01-2005, 07:18 PM   #6
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Even if they are good wouldn't hurt anything to clean them up with a terminal cleaner and wire brush then reinstall them.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 06-01-2005, 11:01 PM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
That makes really good sense, but...My experience has been that electrical problems, due to their intermittent nature, often defy logic. Stuff starts working randomly, so you assume it is fixed when it really is not.
Cleaning the cables never hurts, and has fixed probably 75% of the "no start" problems I have ever had.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-01-2005, 11:05 PM   #8
Tom
driving is in my blood
Tom's Avatar
Thats the nuetral safety switch if the problem is on going, no doubt.
Old 06-03-2005, 01:32 AM   #9
jimfulco
Might be just a bit out of adjustment. Try moving the shifter just a little bit up or down while you turn the key.
jimfulco is offline   Reply With Quote
Old 06-03-2005, 02:10 AM   #10
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
The guys are right. I've had this problem a couple times happen to me when I'm in neutral. The neutral safety switch is located at the base of the steering column right at the floorboard. It has 4 wires going to it. It will only let you start the truck in either park or neutral. Quick and easy fix. Take the wired in connectors off and then I think there's 2 screws. Take it out and replace with a new one.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 06-03-2005, 03:29 AM   #11
ZmOz
Can I just cross a few wires and disable the switch? I'm smart enough to only start it in park.
Old 06-03-2005, 12:20 PM   #12
Greenlee
Greenlee's Avatar
Mine does this quite often. I have to push it all the way up for it to start.
Greenlee is offline   Reply With Quote
Old 06-03-2005, 01:10 PM   #13
cliffsta
Stepsides RULE
cliffsta's Avatar
yeah you pretty much gotta throw it into park for mine to catch. My sis drove my truck and she gingerly shifts (i laugh my ass off at it) and she never puts it all the way.
this is how she shifts. (from park) R..... N.......D (from drive)N..........R........P
this is how I shift RND NRP
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 06-03-2005, 03:03 PM   #14
86 Red_Bowtie
86 Red_Bowtie's Avatar
Pull the wires off of the switch that is mounted on top of your steering column (inside the cab by the firewall) and put a jumper wire in between them, the dang truck will start. Don't bet on the remembering to put in park to start everytime, I thought that myself until I got in a hurry and started it and took off down the drive ONCE---Never again.
Sean
Midwest All Truck Nationals, Riverside, MO - 2008 - 2015
86 Red_Bowtie is offline   Reply With Quote
Old 06-03-2005, 05:13 PM   #15
ZmOz
I did the same thing with my other truck...haven't run over anybody, yet...
Old 06-05-2005, 12:36 AM   #16
jimfulco
Some of those switches also work the backup lights. Two wires are for the BU lights, & the other two are for the starter.
