Old 06-04-2005, 02:29 AM   #1
ckhd
ckhd's Avatar
Removing spring bushings
Anyone have tips on getting the spring bushings out (leaf springs)? Two came out just by pulling with my hand. One came out with a large hammer and a socket, another parially came out, leaving the metal sleeve in the eye. Two refuse to move at all.
They are the (I think) original bushings. Anyone have a sure-fire way to get them out?
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 06-04-2005, 02:36 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Plumber's torch. We usually burn the hard to get ones out...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 06-04-2005, 03:12 AM   #3
Mongo
YES_____NO
Mongo's Avatar
Soak them down with PB Blaster then try to knock them out. If that does not work then torch'em
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 06-06-2005, 12:28 AM   #4
4x4Poet
Sometimes one can use a tapered punch inside the sleeve and hammer away with the end of the spring solidly supported. Worry about removing the punch from the sleeve once the sleeve is out. With no sleeve, the rubber doesn't stand a chance. Propane torch is faster, though.
Edit: I have also used a deep socket that is the size of the sleeve, not the entire bushing. This also usually hammers out the sleeve seperate from the rubber.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 06-06-2005, 05:59 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I run a drill through them until they start to fall apart and then knock them out.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
