Old 06-06-2005, 03:07 PM   #1
backinblack
replacement weatherstripping?
Any low cost alternative to door weatherstripping? I need to replace a piece on a truck I'm selling, but don't want to put another 50.00 from Year One into this truck.....I'll be lucky to get out what I've already put into it, but its a pretty nice truck, but the door weatherstripping is missing altogether....The paint shop couldn't get it off w/out ruining it because someone had glued it in previously.
TIA!!
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Hmmm. Too many pontiacs, not enough chevy trucks yet.
backinblack is offline   Reply With Quote
Old 06-06-2005, 04:12 PM   #2
70c10
67-72 Addict!
70c10's Avatar
S-10 truck/Blazer weatherstrip is soooo much nicer than the factory glue on type!. It's heavier duty and it presses in place so you can remove it (for a paint job) then reinstall it. The 71' I am working on had this installed by the former owner and I'm sold on it now. There have been alot of posts about it. It's always available at the junkyard if you are on a really tight budget.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-06-2005, 06:03 PM   #3
R@nger
Psalm 23
R@nger's Avatar
I'm interested in this also.
Will any year S-10 weatherstripping work?
Also is it more or less expensive than ordering exact replacement weatherstripping for our trucks from Year One, LMC, Summit or other such companies.
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD.
"Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy
R@nger is offline   Reply With Quote
Old 06-06-2005, 06:18 PM   #4
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
Check out this link...I haven't tried it yet but I'm going to...
http://67-72chevytrucks.com/vboard/s....php3?t=122688
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 06-07-2005, 12:29 AM   #5
Nima
Blue 67
I put a set few weeks ago, fitted right on. The problem since then is that door shut very hard. It seems it needs some break in period but in exchange when they are shut you don't hear any noise from outside. I got mine from gmpauls around 60 some dollars. The actuall old fashion ones are around 40-50$ I believe. gmpauls ahs all both version.
Nima is offline   Reply With Quote
Old 06-07-2005, 01:15 AM   #6
backinblack
Hey! Thanks for the response! That should work perfect for this!
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Old 06-07-2005, 11:28 AM   #7
Steven B
Steven B's Avatar
I also used the S-10 weather stripping. It was so much easier to install. I got mine from Wes.
Steven B is offline   Reply With Quote
Old 06-07-2005, 02:17 PM   #8
72c5
72c5's Avatar
hey Steven B-
How did you finish the ends that are exposed when you take your top off?
72c5 is offline   Reply With Quote
Old 06-07-2005, 10:31 PM   #9
Steven B
Steven B's Avatar
The weather stripping was for my pickup. The weather stripping on my Blazer is the original replacement. Glue and clamps.
