67-72 Addict!
Hey guys,
I saw this cool bezel setup for our trucks on ebay. What is this clock out of? ![]()
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
If I am not mistaken that is a clock that GM had BorgWarner make up as an accessory to fit in the same place you have it in. It never made it to the accessory list b/c the '67-'72 series was almost to an end of it's "era".
1971 Cheyenne Super Soon to be converted to '68 front clip. Efland, NC |
CCRider
I had an 86 chevy truck that had a clock like that in it.
------------------ 72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
67-72 Addict!
I'll have to check my local junk yards to see if this is the exact type in a 86'.
Half a bubble off!
Looks to me like the clock is a little off from fitting the hole due to the stem. Makes me wonder if it was a console clock from a '65-'68 chevy that has been adapted to go in that dash. Can't remember what years they used those clocks for sure.
------------------[*]'71 Cheyenne, 402BB[*]Winfield, KS[*] http://barn9.freeservers.com
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
Got 20's????
My 87 has that exact one
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
67-72 Addict!
Sounds like this should be easy to find. Hopefully hooking it up will be just a hot and a ground!
Recovering Truck Driver
looks just like the clock in my 87 that i have in the junkyard, and like the one in my dad's 84.
------------------ Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84 ralleys and 31/10.5s Angel girl: 67 Cutlass convertible 330, 3spd stick Greener: 90 GMC Jimmy 350/auto Chad Stephens Orleans,NE no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
Old member
This is the clock I installed from a 80'S model Chevy truck. It only has a hot and ground wire. You have to cut out the back for the hook ups. It iis very simple to do. Just about any truck of the 80 should have these and all I did was install it. It was taken straight out of the junk yard and installed.
![]() ------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 www.geocities.com/chevy71tpi/main.html] www.picturetrail.com/Andy4639]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
My other Love
make sure you get the clocks that say quartz on the face because the ones made before 1980 didnt have quartz movement and never work anymore
my 74 chevy has a clock which doesnt work and my 77 has a clock which also doesnt work ------------------
Hooter_5@hotmail.com AC/DC RULES!!! www.castlegar.com
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
