Old 06-08-2005, 05:58 PM   #1
BubbaGreen
Torque spec - Driveshaft needed
Hey guys,
Can some one tell me what the proper torque spec is for the endcap to U-Joint where the driveshaft connects to the differential. If it makes a differerence, its a stock 12-bolt. Thanks!!!
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 06-08-2005, 07:20 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Bubba, as silly as it sounds, get them as tight as you possibly can with the box end of the wrench. IIRC it is a 5/16 head, so you aren't going to get 150 ft pounds on it.
I always use a threadlocking compound, and if they look too old or any damage at all...replace them with new.
As far as real torque figures, I really couldn't tel you, but I'm sure some one can though. (asuming you can get a torque wrench in there)
Old 06-08-2005, 07:59 PM   #3
BubbaGreen
Well that is what I was thinking...get them as tight as possible, but then reading about U-Joints, the mfg are suggesting them to be torqued properly to prevent distorting the cups, causing premature failure. Thats why I would like to "correct" torque spec...ie, 20ft-lbs or 120ft-lbs
Old 06-08-2005, 08:31 PM   #4
ratfreak888
i once read 17 ft./lbs. but i always do it exactly like longhorn said
ratfreak888 is offline   Reply With Quote
Old 06-08-2005, 08:48 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
torque them done until you FART
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-08-2005, 09:17 PM   #6
Longhorn Man
bubba, that is interesting, and it does make sence.
However, i still say torque them untill the wrench is about to round off the bolt.
if you do find proper specs, please let us know.
Old 06-08-2005, 09:30 PM   #7
Randy70C-10
Randy70C-10's Avatar
I always tighten the crap out of them, been doing it for over 20 years.
Randy70C-10 is offline   Reply With Quote
Old 06-08-2005, 11:21 PM   #8
Dean23
68cst_ss490
Dean23's Avatar
this is the spec for a 98 gmc 1500...id imagine the 67-72 trucks isnt much different
Rear Axle Yoke Retainer Bolt C/K 1,2,3 Except C3500HD
20 N·m
15 lb ft
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 06-09-2005, 07:51 AM   #9
purple gas
I read somewhere once that when engeneers design things with torque requirments the size of the fastener head is a pretty good clue as to how tight it needs to be. Small wrenches fit small bolts, small wrenches have shorter handles than larger wrenches, the length of the handle determins how much leverage or torque you can apply. So, if you use a wrench and not a socket and tighten it till you fart you'll likely be pretty close wether it be a 3/8 or 1 1/2 bolt. Sort of a built in torque limiter. There are some situations where exact torque is critical and this just sin't good enough, but it's a good guide.. Then again if you live on pickled eggs, beans & cabbage and beer you might fart just bending over.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
