Old 06-13-2005, 02:54 AM   #1
el curioso
el curioso's Avatar
pic's of shocks
Like stated in the title I was wondering if any one could please post some pics of how to posittion the shock and any technical info would also be greatly appreciated thank you.
el curioso is offline   Reply With Quote
Old 06-13-2005, 07:41 AM   #2
jlaird
jlaird's Avatar
In what kind of setup?
jlaird is offline   Reply With Quote
Old 06-13-2005, 12:52 PM   #3
el curioso
el curioso's Avatar
I have trailing arms with a 12" notch. Air bags on trailing arms its just that i dont know if theres an ideal position to place shock like in example on trailing arms, on top of axle, what angle do you get the most from your shocks, can one shock be in front of axle and the other on the rear. If i were to go with a watts link where could i more less place the shocks?
But a pic speaks a million words.
Thank you in advance.
Old 06-14-2005, 09:11 AM   #4
jlaird
jlaird's Avatar
Here's what I have. Some aren't of your particular setup, but you might get some ideas from them.
Josh
Old 06-14-2005, 11:36 AM   #5
TOYOTA61384
The ideal location given any setup in regards to performance is going to be as close the the wheel as possible, and as vertical as possible, that way it will be the most direct acting to that particular wheel, and provide the best performace and handling. Given, there are many applications where that is not possible, but the closer you can get, the better.
Hope that helps
Robert
TOYOTA61384 is offline   Reply With Quote
Old 06-15-2005, 12:30 AM   #6
68LSS1
68LSS1's Avatar
Excellent reply.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 06-15-2005, 02:21 AM   #7
el curioso
el curioso's Avatar
Thank you guys for the data. I'll try that close to the tire but not to close. So that in the end they dont act as limiting straps.
